Constant Projections: Parabolic Trajectory - Accel.
In a parabolic trajectory, acceleration remains constant, specifically in the vertical direction due to gravity. The horizontal component of velocity is constant, while the overall velocity changes due to the varying direction of motion. Speed is not constant throughout the trajectory as it varies with the projectile's height. The discussion highlights confusion between 2D and 3D projectile motion, emphasizing that in 3D, the y-component of velocity changes while the x-component remains constant. Understanding these dynamics is crucial for accurately analyzing projectile motion.
courtney1121
As a projectile moves along its parabolic trajectory, which of the following remain constant (ignoring air resistance, and defining the z-axis to point upward)? More than one answer may be correct!
a. Its speed.
b. Its velocity.
c. Its x-velocity and its y-velocity.
d. Its acceleration
I am thinking the only thing constant is acceleration. My book keeps saying that the horizontal velocity is constant but this is a parabolic trajectory so shouldn't that make a difference? Also velocity is going to change from positive to negative, and speed will change at different points of the trajectory.
Along the Y axis the acceleration is always constant. The speed is constant as long as the acceleration doesn't change. The velocity would be constant as well as its x velocity, however the Y velocity wouldn't be constant because at the highest peak of the projectile the y velocity would be 0.
well i don't think velocity would be constant cause velocity is magnitude and direction and the direction changes so it would change, I think. I'm pretty sure I'm considering the projectile in the zx plane so y will always be 0.
Oh crap this is 3 dimensional. Scratch my post. I was talking about 2 D.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
