What is the Construction of R using Equivalence Classes of Cauchy Sequences?
  • Context: Graduate
  • Thread starter Thread starter autre
    Construction
The construction of the real numbers (R) using equivalence classes of Cauchy sequences is established through the definition of limits and convergence. A sequence {b_n} in the rationals (Q) converges to a limit x, represented as the equivalence class [{b_n}]. The proof hinges on demonstrating that for any ε > 0, there exists an N such that for all n > N, the absolute difference |b_n - x| is less than ε. This confirms that the sequence converges to x, validating the construction of R via Cauchy sequences.
  • Understanding of Cauchy sequences and their properties
  • Familiarity with limits and convergence in real analysis
  • Knowledge of delta-epsilon definitions in mathematical proofs
  • Basic concepts of equivalence classes in set theory
  • Study the proof of convergence for Cauchy sequences in a delta-epsilon framework
  • Explore analysis textbooks that cover the construction of real numbers using Cauchy sequences
  • Investigate the implications of convergence theorems for Cauchy sequences
  • Review definitions and properties of equivalence classes in the context of real analysis
Mathematics students, particularly those studying real analysis, educators teaching the foundations of real numbers, and anyone interested in the rigorous construction of R through Cauchy sequences.
autre
This proof I think is related to our construction of R in class using equivalences classes of Cauchy sequences:
Let a\inR, then there exists a sequence b s.t. {b_n}\inQ for all n\inN and lim {b_n} = x.
Here's my attempt:
Let [{b_n}]\inR be the equivalence class of all Cauchy sequences that converge to x. Thus, [{b_n}] = x. Let {b_n}\in[{b_n}]. Then, \existsr\inQ+ and n\inN s.t. \foralln>N, |b_n -x|<r. Thus, lim {b_n} = x.
I feel like I'm missing something, as if I missed a step somewhere. Ideas?
Here's my attempt:
Hello autre.
Since you are talking about Cauchy sequences, all the convergence theorems automatically are implied (they can be proven for a general Cauchy sequence).
Maybe what you could do is look at the actual proof that all Cauchy sequences converge in the delta-epsilon setting.
Unfortunately the proof that I have is from material I took in a Wavelets course and I can not distribute the content freely, but I'm sure there has to be some analysis book out there that does your standard delta-epsilon proof for these sequences, and based on that you could either use it directly, or use the proof to suggest a valid epsilon for your problem.
I'm sorry I can't be more specific at this time, but again if the sequence is a valid Cauchy sequence, then there really should not be more to do.
Hopefully someone more well versed than myself can give you more specific advice (and correct me if I am wrong).
How are you defining such things as "a- x" (a rational) and "|x|" for x an equivalence class of Cauchy sequences?
How are you defining such things as "a−x" (a rational) and "|x|" for x an equivalence class of Cauchy sequences?
Good question. That didn't really make sense. Maybe I should have:
Let {b_n}∈[{b_n}] and {a_n}}∈x. Then, ∃r∈Q+ and n∈N s.t. ∀n>N, |b_n -a_n|<r. Thus, lim {b_n} = x.
Would that work?
  • · Replies 24 ·
