How can continued fractions be used to prove a deep result in mathematics?
  • Thread starter Thread starter DeadOriginal
    Fractions
The discussion focuses on using continued fractions to prove a mathematical result involving the equation x² - ax - b = 0, where a and b are positive constants. The user attempts to derive the continued fraction representation of √(α² + β) but struggles with finding appropriate values for a and b. They initially faced challenges transforming the equation into a continued fraction and combining different forms for varying values of β. However, after revisiting the suggestion of setting a = 2α and b = β, they successfully found a solution. The conversation highlights the dynamic nature of mathematical problem-solving and the importance of collaborative input.
DeadOriginal
Let x be any positive real number and suppose that ##x^2-ax-b=0## where ##a,b## are positive. I would like to use the equation that I provided in relevant equations which I proved to prove that
\sqrt{\alpha^{2}+\beta}=\alpha+\cfrac{\beta}{2 \alpha+\cfrac{\beta}{2 \alpha+\cfrac{\beta}{2\alpha+\ddots}}}
where ##\alpha,\beta>0##.
I proved that
x=a+\cfrac{b}{a+\cfrac{b}{a+\cfrac{b}{a+\ddots}}}.
I tried to do things like find values of ##a,b## so that when I transformed the equation ##x^{2}-ax-b=0## into a continued fraction that I would get the desired continued fraction with ##x=\sqrt{\alpha^{2}+\beta}## but that didn't work out.
I also tried changing ##\sqrt{\alpha^{2}+\beta}## directly into a continued fraction using the canonical continued fraction algorithm but I then had to consider different values of ##\beta## which would give me different continued fractions that I didn't really know how to combine to create the desired continued fraction.
I tried to plug ##x=\sqrt{\alpha^{2}+\beta}## into ##x^{2}-ax-b=0## and then solve for ##a,b## but that didn't get too far with two variables and one equation.
If you set a = 2α and b = β, what are the roots of x2-ax-b?
I don't know why but I remember trying that and it didn't work but now that I try it again after you mention it, it works. Thanks!
A deep result in maths is that arithmetic and algebraic results are NOT static over time, but depend on what help you get!
:smile:
:smile:
Amen! Haha.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
