Continuing my experimentation with bismuth
This discussion centers on the unique properties of bismuth, particularly its behavior when molten and its interaction with air. When heated, bismuth exhibits colorful oxides, but retains a shiny, lustrous appearance when polished with "Scouring cream," a product used for metal surfaces. The metal does not oxidize easily after polishing, despite tarnishing rapidly when molten. Additionally, bismuth is noted for its low density in solid form, allowing it to float on its molten state, and its weak diamagnetic properties, which can be demonstrated using neodymium magnets.
  • Understanding of chemical kinetics and oxidation processes
  • Familiarity with the properties of bismuth
  • Knowledge of polishing techniques for metals
  • Basic principles of magnetism and diamagnetism
  • Research the chemical properties of bismuth and its oxides
  • Explore the effects of temperature on chemical reactions
  • Learn about the applications of diamagnetic materials
  • Investigate various metal polishing techniques and products
Chemists, materials scientists, hobbyists experimenting with metals, and anyone interested in the physical properties of bismuth and its applications.
BetaZeta2016
The more i study this strange element, the more interesting it becomes.
I found that bismuth only shows it's colorful oxides when exposed to air while hot/molten.
I decided to go outside and polish the sample using an abrasive liquid known in Brazil as "Saponáceo Cremoso".
Don't know what it's called in english-speaking countries.
Edit: It's called "Scouring cream" in english.
Anyway, it's used to polish aluminum cookware as well as any other metal surfaces.
So i took my bismuth sample out and started polishing.
The metal finally showed it's natural appearance: A lustrous, shiny and silvery material that resembles lead or iron.
But something more happened: It didn't oxidize. Even after being exposed to air, water or even the oils from my hand, it's still shiny, without any noticeable color change.
But when molten, it tarnishes instantaneously!
Anyone knows why?
Chemistry news on Phys.org
BetaZeta2016 said:
So the heat acts as a catalyst here.
No. Catalyst is a catalyst, heat is a heat. Both speed up the reaction, but for completely different reasons.
Likes BetaZeta2016
Oh, nice. Thank you for clarifying :smile:.
As you were melting Bismuth and already messing up one pan: Did you observe the solid bismuth to float on the melt? Bismuth is one of the few substances (like water) where the solid is less dense than the melt.
Likes BetaZeta2016
Yes, i did!
While the bismuth was molten, there was a small chunk floating on the top of the liquid.
I won't do it on the kitchen again. One pan just went to the trash because of this hehe. :biggrin:
Bismuth is also a relatively strongly diamagnetic substance, i.e. it gets repelled by a magnetic field. If you mount your probe on a string and bring a strong magnet close (best one of these small neodymium magnets) it will turn away.
Likes BetaZeta2016
Cool experiment too! I tried it with some magnets from old hard drives.
Bismuth diamagnetism is very weak.
But still stronger than any other material i have ever seen.
  • · Replies 16 ·
12K
  • · Replies 19 ·
  • · Replies 21 ·
  • · Replies 16 ·
