Continuity characterization (metric spaces)
  • Thread starter Thread starter Carl140
    Continuity
The problem involves the characterization of continuity in metric spaces, specifically examining the relationship between open balls in the codomain and the closure of images of open balls in the domain. The original poster seeks to prove a containment property related to continuous functions between metric spaces.
  • The original poster attempts to leverage the definition of continuity and the properties of open and closed sets but expresses uncertainty about the next steps. Some participants suggest considering a proof by contradiction and exploring the implications of the assumption that the containment does not hold.
The discussion is ongoing, with participants exploring different angles and approaches to the problem. Some guidance has been offered regarding the use of contradiction, and the original poster has articulated their thought process, indicating a productive exchange of ideas.
There is a noted assumption that the original poster is working under specific constraints related to the definitions of open and closed sets in metric spaces, as well as the continuity of the function involved. The relationship between the radii of the balls is also a point of discussion.
Carl140
Let (X,d) and (Y,d') be metric spaces and f: X-> Y a continuous map.
Suppose that for each a>0 there exists b>0 such that for all x in X
we have:
B(f(x), b) is contained in closure( f(B(x,a))).
Here B(f(x),b) represents the open ball with centre f(x) and radius b.
Similarly B(x,a) represents the open ball with centre x and radius a.
Prove that for all x in X and for every c > a :
B(f(x), b) is contained in f(B(x,c)).
No clue here, I took an y element in B(f(x),b) so d(f(x),y) < b.
Then by assumption B(f(x),b) is contained in closure(f(B(x,a)) so y
is in closure(f(B(x,a)), and then?
If you don't get an answer, this forum
http://www.mathhelpforum.com/math-help/
should help you immensely.
Questions in their section on analysis are typically very well answered.
This is ripe for a proof by contradiction approach (which may even yield a direct proof).
If there is a c such that B(f(x),b) is not contained in f(B(x,c)) what does that mean?
Hi Matt, thanks for your reply. Assume there exists a point q in B(f(x),b) such
that q is not in f(B(x,c)).
Now since c>a it follows that B(x,a) is contained in B(x,c).
Hence f(B(x,a)) is contained in f(B(x,c)).
Since q is not in f(B(x,c)) then q is not in f(B(x,a)).
But f is continuous so f(closure(B(x,a))) is contained in closure(f(B(x,a)).
I'm stuck here. What else should I do?
  • · Replies 18 ·
