Continuity for Multivariable Functions
Continuity for multivariable functions can be defined using the epsilon-delta approach similar to single-variable functions, where continuity at a point involves finding a delta for every epsilon that satisfies the distance condition. The discussion highlights that proving continuity for functions like f(x,y) = x + y can rely on established continuity of basic functions and theorems regarding operations like addition and multiplication. It emphasizes that continuity along axes does not guarantee overall continuity, as illustrated by a counterexample. The conversation also touches on the need for practical examples in learning materials, suggesting that foundational texts may not sufficiently cover multivariable cases. Understanding continuity in this context is essential for further study in topology and analysis.
brydustin
Just curious how to define continuity for mult dim. functions. I know that the topological and set theorectical definitions work in a very abstract setting; but I just don't know how to prove (for example) that f(x,y) = x + y or f(t,z) = t*z is continuous, other than saying something like: Well because f(t)=t is continuous and ..., therefore the composition of... and hence it is continuous. I was wondering if there is a generalization for delta-epsilon defition that would cover any (actual) function (as opposed to some abstract space,etc): R to R and R^n to R^m (where m,n are any positive integers and may or may not be equal). Can we possibly express epsilon-delta as a vector? A stretch maybe? Thanks for any help,... I'm teaching myself topology and more analysis right now! got to love it!
What do you mean an (actual) function as opposed to some abstract space? This doesn't seem to make much sense because we obviously need the point-set before we can define the function. In a metric space, we can define continuity in terms of the metric, and if we have a function f from R^n to R^m, we're just working with the usual topology. Thus continuity of f at a point a in R^n is just the same old "for every epsilon > 0 there exists a delta > 0 such that d(x, a) < delta implies d(f(x), f(a)) < epsilon" where x is in R^n and d is the standard euclidean distance.
what are you reading? Isn't this explained in every book on several variable calculus? i like courant, volume 2, and wendell fleming's book. basically you define the length of a vector |(a,b,c)| = sqrt(a^2+b^2+c^2), and do all the epsilon delta in those terms, word for word the same as in one variable.
It's differentiability where you have to do something new, because you can't divide vectors.|x+y| ≤ |x| + |y|, implies continuity of addition.
Of course, even with functions of one variable, nobody would use the epsilon-delta kind of argument for an "actual" function something like
f(x) = \frac{e^{\sin(x)}\sqrt{1+x^3}}{3x^2+7}
You prove continuity for the basic functions and use the theorems about products, quotients, compositions etc. The same thing is true for functions of 2 variables.
Note that continuity along lines parallel to the z and t axes does not imply continuity of the function; consider
<br /> f(z,t) = \left\{\begin{array}{ll}<br /> \frac{|t|e^{-\frac{|t|}{z^2}}}{z^2} &amp; z\neq 0 \\<br /> 0 &amp; z=0 \end{array}<br />
in the neighborhood of (0,0). Although the limits along the axes both exist and are equal to the value of the function at (0,0), \lim_{(z,t)\rightarrow (0,0)} f(z,t) does not exist.
Actually the book I'm using is Real Analysis by Norman B Haaser and Joseph A Sullivan. It explains the concept of continuity on metric spaces but doesn't given any examples other than those of one variable however wants the reader to do examples of more than one variable as practice problems.
So I still don't have a clue how to prove that x+y is continuous. Any more help?
  • · Replies 18 ·
