Why does the cube root function have a discontinuous derivative at x=0?
  • Context: Graduate
  • Thread starter Thread starter {???}
    Continuity
The cube root function f(x)=x^{1/3} has a derivative f'(x)=\frac{1}{3}x^{-2/3}, which is discontinuous at x=0 due to a vertical asymptote. Despite this, the graph appears smooth, lacking angles or cusps, as it approaches the same slope from both sides of the discontinuity. The discussion highlights the distinction between "apparently smooth" and "mathematically smooth" functions, emphasizing that f(x) is not in C^∞ but in C^0 or D^1. The conversation also touches on the implications of rotating coordinate axes and parameterization to analyze the function's behavior.
  • Understanding of calculus, specifically derivatives and continuity.
  • Familiarity with the cube root function and its properties.
  • Knowledge of mathematical smoothness classifications (C^0, C^∞, D^1).
  • Basic concepts of coordinate transformations and parameterization.
  • Explore the properties of discontinuous derivatives in functions like f(x)=x^{2/3} and y=|x|.
  • Study the implications of coordinate transformations on function behavior.
  • Learn about parameterization techniques for analyzing curves in calculus.
  • Investigate the definitions and differences between C^0, C^1, and C^∞ smoothness in mathematical functions.
Mathematicians, calculus students, and educators seeking to deepen their understanding of function behavior, derivatives, and the nuances of mathematical smoothness.
Hey everyone,
I was just curious about the nature of the cube root function f(x)=x^{1/3}. I know that its derivative is obviously \frac{1}{3}x^{-2/3} which has a discontinuity at x=0. However, in the non-mathematical sense, the graph of y=f(x) looks smooth - I don't see any angles or cusps like y=|x| or y=x^{2/3}.
Now, granted, the discontinuity in f'(x) is a vertical asymptote where \delta(M) can always be chosen such that:
|x|<\delta \Rightarrow f'(x)>M
So unlike the asymptotes of \frac{1}{x} for example, or the derivative of y=x^{2/3}, the function both sides of the discontinuity "goes to positive infinity" so the tangent line to x^{1/3} approaches the same slope on either side of x=0.
My question is: Is this a good enough explanation as to why an apparently smooth function has a discontinuous derivative? If not, why doesn't this violate the definition of a (mathematically) smooth function? (This may border on a philosophical question, so my apologies in advance if so)
Yes to the first, but I don't understand your reasoning in the second. How do you think it would lead to such? Mathematically smooth is very much more demanding than apparently smooth.
My reasoning is best described mathematically as follows (and I admit, rather poorly at that):
Suppose we rotate the coordinate axes by \frac{\pi}{6} (i.e., counterclockwise) and label the new grid (x^*,y^*). We could technically have in this new coordinate system a function y^*=f^*(x) that, although not expressible in terms of elementary functions, describes the graph of y=x^{1/3}.
My claim is that
\frac{\mathrm{d}y^*}{\mathrm{d}x}
is continuous. For other functions with "clearly" discontinuous derivatives, i.e., y_2=|x|, y_3=x^{2/3},\ldots this is not the case.
Just wanted to point this out because it's different from most other piecewise-smooth functions in that respect. Any thoughts?
Your question is kind of a non-question - your f(x) is not mathematically smooth, that is, it is not in C^inf. It is only in C^0 or D^1.
OK, so you're thinking of it as a smooth curve in the plane, in more of a co-ordinate free sense.
That's true, but that is rather different from a function. E.g. you could rotate it so that there are multiple y values for some x values, so now it is not even a function in the standard definition.
One way around this is to parameterise, making x and y functions of some other variable that changes monotonically along the curve.
  • · Replies 17 ·
