Contradiction in the formation of an electric dipole
The discussion centers on the formation of an electric dipole in a hydrogen atom when subjected to an external electric field. It critiques the classical treatment of the proton and electron as stationary point charges, emphasizing that the electron's circular orbit must be considered with its centripetal acceleration. The Bohr model indicates that the external electric field distorts the orbit into an ellipse, leading to a dipole moment. However, a balance equation derived from classical physics suggests that increased electric field strength results in a smaller separation between the electron and proton, contradicting traditional textbook explanations of induced dipoles.
  • Understanding of the Bohr model of the hydrogen atom
  • Familiarity with electric dipole moments
  • Knowledge of classical mechanics, particularly centripetal acceleration
  • Basic principles of quantum mechanics and atomic structure
  • Research quantum mechanical models of the hydrogen atom
  • Study the effects of external electric fields on atomic structures
  • Explore the concept of induced dipoles in various atomic systems
  • Examine the limitations of classical physics in atomic-scale phenomena
Students and researchers in physics, particularly those focusing on atomic physics, quantum mechanics, and electromagnetism, will benefit from this discussion.
guv
Imagine a hydrogen atom isolated initially. Then a uniform electric field ##E## is turned on at the atom. This pulls electron in one direction pushs proton to the other direction. Forming a dipole as explained in most textbooks. In addition the stronger the external electric field, the greater the separation between electron and proton. However, when examining the set up in details, one can see the balance of the electron or the proton is between two electric forces
$$e E = \frac{ke^2}{d^2}$$
where ##d## is the separation of the electron from the proton. This balance equation predicts the distance must become smaller when external electric field ##E## becomes stronger, contradicting with what most books explain how induced dipoles form. Any suggestion on how to reconcile this? Thanks,
$$d = \sqrt{\frac{ke}{E}} \propto \sqrt{\frac{1}{E}}$$
Solution as stated in the problem description.
Hi.
Your analysis treats the proton and electron in a hydrogen atom as if they are classical, stationary, non-accelerating, point charges separated by a distance d. This is wrong and leads to totally incorrect results.
If we use the simple Bohr model, the electron moves in a circular orbit (radius d) with a particular angular momentum, so has (centripetal) acceleration which *must* be accounted for.
Thinking classically, the external electric field changes the shape of the orbit so that it becomes an ellipse with its semi-major axis longer than d and the proton at a focus, causing the atom to acquire a dipole moment.
A more rigorous quantum mechanical analysis is needed really, as the idea of point charges moving in definite orbits is wrong.
guv said:
Homework Statement:: Imagine a hydrogen atom isolated initially. Then a uniform electric field ##E## is turned on at the atom. This pulls electron in one direction pushs proton to the other direction. Forming a dipole as explained in most textbooks. In addition the stronger the external electric field, the greater the separation between electron and proton. However, when examining the set up in details, one can see the balance of the electron or the proton is between two electric forces
Relevant Equations:: $$e E = \frac{ke^2}{d^2}$$
Don't forget that in the absence of an external E field the electron (classically) whizzes around the nucleus, so the coulomb force is offset by the centripetal force.
If an external E field is exerted on the atom, there will be a net attraction of the electron in the direction opposite the external field. The atom (electron & proton) forms a dipole moment in the same direction as that of the external field.
Edit: I edited out the equation of equilibrium since it's most likely wrong.
You'd have to take changes in orbital dynamics into account which I don't want to do.
  • · Replies 25 ·
