Contravariant vectors and Transformation Equations
4 replies · 2K views · last reply
ashwinnarayan
This is me doing some independent study on Tensors because I eventually hope to understand General Relativity.
My question is about the following equation which describe hoe the components of a displacement vector transform when there is a change in the coordinate system.
[itex]d{y}^1 = \frac{∂y^1}{∂x^1} dx^1 + \frac{∂y^1}{∂x^2} dx^2[/itex]
To understand with and example, I drew out a normal 2D Cartesian Coordinate system with the axes [itex]x^1[/itex] and[itex]x^2[/itex] and drew a new coordinate system with axes [itex]y^1[/itex] and [itex]y^2[/itex]. This new coordinate system was just the x system rotated anticlockwise by 30 degrees. I drew a displacement vector which went from (1,1) to (2,2) essentially a displacement vector of [itex](dx^1,dx^2)[/itex]
Since I already know linear algebra fairly well, I used the inverse transformation of a clockwise rotation of 30 degrees
[itex] \left( \begin{array}{ccc}<br /> \frac{\sqrt{3}}{2} & \frac{1}{2} \\<br /> \frac{-1}{2} & \frac{\sqrt{3}}{2} \\<br /> \end{array} \right) [/itex]
to find the values of [itex]y^1[/itex] and [itex]y^2[/itex] and got
[itex]dy^1 =\frac{ \sqrt{3}}{2} dx^2 + \frac{1}{2} dx^2[/itex]
Now try as I might I cannot seem to be able to figure out how the heck [itex]\frac{∂y^1}{∂x^1} = \frac{\sqrt{3}}{2}[/itex] and [itex]\frac{∂y^1}{∂x^2} = \frac{1}{2}[/itex]
Can someone help me out?
1. If you're doing tensors this book (it's free) is the single best book I've read on introducing the subject
http://www.math.odu.edu/~jhh/counter2.html
2. if the equation you wrote for [itex]dy^1[/itex] is correct then [itex]\frac{\partial y^1}{\partial x^1} = \frac{1}{2}[/itex] and [itex]\frac{\partial y^1}{\partial x^2} = \frac{\sqrt{3}}{2}[/itex]
I think you may have mixed you indices up, try writing out the transformation equations in the form of
[itex]y^1 = f_1(x^1)+g_1(x^2)[/itex]
[itex]y^2 = f_2(x^1)+g_2(x^2)[/itex]
it'll help you out a lot
Oh! I'm really sorry! :frown: It should have been
[itex]dy^1 =\frac{ \sqrt{3}}{2} dx^1 + \frac{1}{2} dx^2[/itex]
And that book is really good. Thanks!:biggrin:
About trying to write the equation in that format I think the problem maybe that I'm not writing it down correctly.
In my coordinate system transformation (which I've attached) am I right in saying that
[itex]y^1 = \frac{1}{\sqrt{3}}x^1[/itex] because [itex]y^1[/itex] is essentially a straight line with a gradient of [itex]\frac{1}{\sqrt{3}}[/itex]?
  • Diagram of two coordinate systems sharing an origin: perpendicular axes x^1 (horizontal) and x^2 (vertical), and rotated axes y^1 and y^2, with y^1 at 30 degrees above x^1 and y^2 at 60 degrees from x^1.
Yeah, if [itex]dy^1 = \frac{\sqrt{3}}{2} dx^1 + \frac{1}{2}dx^2[/itex] then your partial derivatives are correct since the partial derivative with respect to one variable is just what you get when you set the 'd'*other variables to zero
For your transformation equation, think about what happens to your position in the y coordinates as you increase x1 then when you increase x2, each time you change your x1 coordinate you are changing your position in both of the y coordinates, if you understand what I mean.
if you move from x1=0 to x1=3, you've increase your y1 position but you've also decreased your y2 position since you are not below the y1 axis
Ah! I think I get it!
I've been considering the cartesian equation instead of the vector equation!
So [itex]y^1 = \frac{\sqrt{3}}{2} x^1 + \frac{1}{2} x^2[/itex] !
Then I can get [itex]\frac{∂y^1}{∂x^1} = \frac{\sqrt{3}}{2}[/itex] and [itex]\frac{∂y^1}{∂x^2} = \frac{1}{2}[/itex]
Yes, I get it now. Thanks a lot for helping me!
