What is the temperature of an iron bar after 1 hour of convection heating?
The discussion centers on calculating the temperature of an iron bar after one hour of convection heating using an electric cable with a power output of 22.5 kW. The formula provided for the final temperature is T_final = F + Q/(u*A*L), where Q is the power, u is the coefficient of convective exchange, A is the area of the iron bar, and L is the length of the cable. Given the initial temperature of 5 degrees Celsius and an external temperature of -4 degrees Celsius, the parameters for the iron bar include a mass of 529.13 kg, an area of 1.68 m², and a heat capacity of 450 J/kg*K. The discussion seeks validation of the temperature increment term Q/(u*A*L) for accuracy.
  • Understanding of heat transfer principles, specifically convection.
  • Familiarity with thermal properties of materials, particularly iron.
  • Knowledge of the formula for calculating temperature changes in conductive materials.
  • Basic proficiency in physics, particularly thermodynamics.
  • Research the principles of convection heat transfer and the associated coefficients.
  • Study the impact of thermal conductivity on temperature changes in materials.
  • Learn about the specific heat capacity of various materials and its application in thermal calculations.
  • Explore numerical methods for solving heat transfer problems in practical scenarios.
Engineers, physicists, and students involved in thermal analysis, particularly those working with heat transfer in materials like iron. This discussion is beneficial for anyone looking to understand the effects of convection heating on solid objects.
dvd84
Hello, my problem is the following:
I have an iron bar, which can be heated by convection through an electric cable with power Q.
I want to know the temperature of the iron bar after 1 hour has passed, both in the case when the power is
turned on and when it is off (Q=0).
the input parameters are the temperature of the iron bar at instant zero and the environmente temperature,
the output is the new temperature of the iron bar after 1 hour.
Thank you.
Science news on Phys.org
Dr. Courtney said:
no it is not an homework problem, I have a solution which is
where F is the formula that updates the temperature and it works quite well.
The term
Q/(u*A*L)
represents the increment of temperature due to the electric cable, where Q is the power, u the coefficient of convective exchange, A the area of the iron bar and L the length of the cable. I want to check the correctness of the term Q/(u*A*L), if you may help me.
I have an iron bar not insulated, of length 6 meters, heigth 28 cm and width 4 cm, hence the area is 1.68 m^2 and the mass is 529.13 Kg.
The heat capacity of iron is 450 J/Kg*K.
The thermal conductivity of iron is 0.023 W/m*K.
The thermal expansion coefficient is 0.0037 C^-1.
The density of air is 1.30 Kg/m^3.
The dynamic viscosity of air is 17.157 * 10^-6 Pa*sec.
I assume that at time zero the internal temperature of the iron bar is 5 degrees Celsius, the external temperature is -4 degrees Celsius (the bar is not insulated).
The power Q that pass through the cable is 22,5 KWatt, and the length of the cable is 14 meters, the heat transfer between the cable and the iron bar is by convection.
I need to know after 1 hour has passed the new internal temperature of the iron bar.
Thanks
