Convergence of a series, lots of logs
  • Thread starter Thread starter sillyus sodus
    Convergence Series
The convergence of the series \(\sum_{n=1}^{\infty}\frac{1}{n\log{n}\left(\log{\log{n}}\right)^k}\) is established as being dependent on the condition \(k > 1\). The Cauchy condensation test was applied, leading to the transformation of the series into a form that allows for further analysis. The discussion indicates that the dominant term in the convergence behavior is \(n^k\), which suggests that the series converges when \(k\) exceeds 1. The Integral Test was also mentioned as a potential method for further exploration.
  • Understanding of series convergence tests, specifically the Cauchy condensation test.
  • Familiarity with logarithmic functions and their properties.
  • Basic knowledge of asymptotic notation and dominant term analysis.
  • Experience with the Integral Test for convergence.
  • Study the Cauchy condensation test in detail to understand its applications in series convergence.
  • Explore the properties of logarithmic functions, particularly in the context of series.
  • Learn about asymptotic analysis and how to identify dominant terms in series.
  • Investigate the Integral Test for convergence and its relationship with other convergence tests.
Mathematics students, educators, and researchers focused on series convergence, particularly those studying advanced calculus or real analysis.
sillyus sodus
Show that this sum is convergent if and only if k>1 :
I've applied the Cauchy condensation test, giving:
\frac{2^n}{2^n\log{2^n}\left(\log{\log{2^n}}\right)^k}
=\frac{1}{n\log{2}\left(\log{n\log{2}}\right)^k}
Then I figured I just apply it again?
\frac{2^n}{2^n\log{2}\left(\log{\left(2^n\log{2}\right)}\right)^k}
=\frac{1}{\log{2}\left(n\log{2}+\log{\log{2}}\right)^k}
But then what? I'm aiming for something along the lines of:
\frac{1}{C\cdot n^k}
So then the answer is obvious but the best I can come up with now is that the term inside the brackets will come out like:
\left(n\log{2}+\log{\log{2}}\right)^k = n^k\log{2}^k + \mathit{terms\ of\ order\ <k}
And therefore the n^k term will dominate the convergence behaviour... Am I on the right track here or have I missed some algebraic trick? Am I wrong to apply the test a second time? I don't want an answer here if that's possible, just some kind of hint. Thanks in advance.
PS for some reason my tex has failed somewhere but you should get the idea...
  • · Replies 17 ·
  • · Replies 22 ·
