Convergence of Sequences and closed sets
The theorem discussed states that a subset S of a metric space E is closed if and only if every convergent sequence of points in S has its limit in S. The confusion arises in interpreting the "if" portion, where it is incorrectly assumed that a subset containing a convergent sequence and its limit must be closed. The example provided, the sequence 1/n^2 within the open interval (-1,1), illustrates that a convergent sequence can exist in an open set without the set being closed. The critical point is that not every convergent sequence in an open set guarantees closure.
  • Understanding of metric spaces and their properties
  • Familiarity with the concept of convergent sequences
  • Knowledge of closed and open sets in topology
  • Basic principles of real analysis as outlined in "Introduction to Analysis" by Rosenlicht
  • Study the definitions and properties of closed and open sets in metric spaces
  • Explore examples of convergent sequences in both closed and open sets
  • Learn about limit points and their significance in topology
  • Review the implications of the Bolzano-Weierstrass theorem in relation to closed sets
Students of real analysis, mathematicians studying topology, and anyone seeking to deepen their understanding of metric spaces and the properties of closed sets.
scottyg88
This is the Theorem as stated in the book:
Let S be a subset of a metric space E. Then S is closed if and only if, whenever p1, p2, p3,... is a sequence of points of S that is convergent in E, we have:
lim(n->inf)pn is in S.
From "introduction to Analysis" Rosenlicht, page 47.
I understand the "only if" portion of this theorem, in that a closed subset implies the limit will lie in the subset. However, I'm missing something in the "if" portion, in that if a subset contains a convergent sequence and the limit is contained in the subset, then the subset must be closed. Maybe I am reading this wrong, but could it not be the case that a convergent sequence (and its limit) lie completely in an open subset. For example, the sequence 1/n^2 is contained completely in (-1,1), an open subset of the metric space R.
BTW... I've used the info in this forum for a long time... glad to finally be a part of it :)
The statement asserts that whenever you have a convergent sequence of terms in A, the limit point for the sequence is also in A. One such sequence is not sufficient.
Does the statement not also imply that a subset containing a convergent sequence AND its limit must be a CLOSED subset in the metric space? This is the part I have a question about.
Why could a subset contain a convergent sequence and its limit, but be an OPEN subset?
Thanks in advanced for your help...
I assume your definition of a set S being closed is that it contains all of its limit points. So you are looking at the theorem that a set is closed if and only if the limit of any convergent sequence of points of S is itself in S. The "only if" part of this says:
If every converent sequence in S has its limit point in S, then S is closed. I think you are missing the "every". The problem with your example is there is a sequence in S that doesn't have the property: {1 - 1/n}, so the interval isn't closed.
I see! Quite an oversight on my part... thanks for the help!
  • · Replies 16 ·
