Converging and diverging nozzles
  • Thread starter Thread starter tsukuba
    Converging
The discussion focuses on calculating the static temperature and pressure of air flowing through a device with given stagnation conditions: stagnation pressure of 0.6 MPa, stagnation temperature of 400° C, and velocity of 570 m/s. The correct equation to determine static temperature is T = Tt - (V² / (2 Cp)), where Cp is 1.005 kJ/kg·K. The user initially misapplied the equation, leading to an incorrect result of -323.5 K instead of the correct 518.6 K. The error stemmed from improper algebraic manipulation of the equation.
  • Understanding of thermodynamics, specifically the concepts of stagnation temperature and pressure.
  • Familiarity with the specific heat capacity (Cp) of air, particularly 1.005 kJ/kg·K.
  • Basic algebra skills for manipulating equations.
  • Knowledge of fluid dynamics principles related to airflow and velocity.
  • Review the derivation and application of the energy equation in thermodynamics.
  • Study the concept of stagnation properties in fluid mechanics.
  • Learn about the impact of velocity on static temperature and pressure in compressible flow.
  • Practice solving similar problems involving the conservation of energy in fluid systems.
Students studying thermodynamics, engineers working with fluid dynamics, and anyone involved in aerospace or mechanical engineering applications related to airflow and energy calculations.
tsukuba
air flows through a device such that the stagnation pressure is 0.6 MPa, the stagnation temperature is 400° C, and the velocy is 570 m/s.
Determine the static pressure and temperature of the air at this state.
Tt=T + V2 / 2 Cp where Cp is 1.005 Kj/ Kg* ° K
what I did was Isolate for T since that is what I am looking for. [/B]
2 Cp x Tt - v2 = T
somewhere in here I know I have to throw in 1000m2/s2/ Kj/kg °k
when I do that I get -323.5 ° K
the answer is 518.6 ° K
Someone please let me know where I have gone wrong. Thank you
2 Cp x Tt - v2 = T
Your algebra is a little dodgy in solving for T.
The correct equation is:
Tt = T + [V2 / (2 Cp)]
which means your equation for T is incorrect. :frown:
brackets or no brakets, wouldn't T stay the same when isolating it?
T = Tt - [V2 / (2 Cp)]
But you had
2 Cp x Tt - V2 = T
which is not the same. Apparently, you multiplied only one side of the equation by (2 Cp).
hmm, not sure how you get that equation but I'm still not getting the right answer. I will have to ask the professor tomorrow
