Conversion Formula for Intensity Units: SI to AU Explained
  • Thread starter Thread starter russel.arnold
    Intensity Units
The SI unit of intensity is watts per square meter (W/m²), while AU, or arbitrary units, is often used when absolute intensity values are not critical. The conversion from SI to AU is not straightforward, as AU represents a relative scale rather than a fixed measurement. In many cases, knowing the relative intensity suffices, especially for applications like analyzing decay time constants from intensity curves. The discussion highlights the importance of context when interpreting intensity measurements in different units. Understanding these distinctions is crucial for accurate data analysis in various scientific fields.
russel.arnold
I know that the SI unit of Intensity is W/m^2. I came across one more unit of intensity -> AU..but could not get much on that. Can anybody tell me the conversion formula ( from SI to AU ) ?
When displaying intensity AU or Arb.u., mostly certainly measn 'Arbitrary units', which means that the absolute value of the intensity is not known and/or not important. For intensities, quite often it's enough to know only the relative value, e.g. when inferring a decay time constant from an intensity curve.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
