Conversion from Polar to Cartesian (ellipse)
The discussion focuses on converting a conic section given in polar coordinates to its standard Cartesian form. The initial equation is r = 1/(8 - 4sin(θ), which leads to the transformation using the relationships x = rcos(θ) and y = rsin(θ). Participants explore multiplying both sides by (8 - 4sin(θ)) and substituting y for rsin(θ) to simplify the equation. The transformation results in an equation involving x and y, ultimately leading to a quadratic form. The conversation highlights the challenges faced in correctly manipulating the equations to achieve the desired standard form.
nitroracer
Convert the conic section to standard form. r=\frac{1}{8-4*sin(\theta}
x=rcos(\theta)
y=rsinx(\theta)
r^2=\frac{1}{64-64*sin(\theta)+16sin^2(\theta)}
r^2= x^2 + y^2
I can see the y=r*sin(\theta) but not the x!
so what does r= according to the definitions and what does sin(theta)= according to the definitions? What can you do with that knowledge?
I would multiply both sides by (8-4sin(theta)) and then you can replace rsin(theta) with y. And then you can use your identity r^2 = x^2 + y^2.
I came up with r= \sqrt{x^2 + y^2} and sin(\theta)=y/r
\sqrt{x^2 + y^2} = \frac{1}{8-4sin(\theta)}
\sqrt{x^2 + y^2} = \frac{1}{8-(\frac{4y}{r})}
x^2 + y^2 = 64 - \frac{64y}{r} + \frac{16y^2}{r^2}
pretty sure I chose the wrong order of events there...
But when I tried the other suggestion I got pretty close to an answer:
8r - 4rsin(\theta) = 1
8r - 4y = 1
8r = 1 + 4y
r = \frac{1+4y}{8}
r^2 = \frac{1+8y+16y^2}{64}
x^2 + y^2 = \frac{1+8y+16y^2}{64}
64x^2 + 64y^2 = 1+8y+16y^2
64x^2 + 48y^2 - 8y = 1
and this is where I get stuck because 48y^2 - 8y +/- ___
r= r/(8r-4y)
8r-4y=1
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 20 ·
  • · Replies 19 ·
