Convert 0.E to Binary | Hexadecimal to Binary Conversion
  • Thread starter Thread starter sporus
    Binary Convert
The original poster attempts to convert the hexadecimal number 0.E to binary. The problem involves understanding the conversion process between different numeral systems, specifically focusing on hexadecimal and binary representations.
  • Participants discuss the method of converting fractional numbers from hexadecimal to binary, with some questioning the calculations presented by the original poster. There is also mention of converting hexadecimal to decimal as a potential approach.
Some participants have provided corrections to the original poster's calculations, indicating errors in the multiplication steps. Others have suggested alternative methods for conversion, but there is no explicit consensus on the best approach yet.
There is a focus on the conversion of hexadecimal fractions, and some participants note the importance of maintaining the decimal point during conversion. The original poster's method appears to be based on a misunderstanding of the conversion process.
sporus
convert 0.e to binary
the method the teacher taught for numbers less than zero was multiply by the desired base. then take the whole number and write it down as part of the converted number and drop it.
ie 0.8*2 = 1.6 drop the 1 and you have 0.6
then take the leftover and multiply it over and over again until you have reaches the number of significant digits or you reach 1.0
write down all the numbers that were dropped and you have the number in a different base
so i did
0.E * 2 = 1.C
0.C * 2 = 1.8
0.8 * 2 = 1.6
0.6 * 2 = 1.2
but the answer i come up with is wrong because i checked it here.
http://www.mathsisfun.com/binary-decimal-hexadecimal-converter.html
In hex, 0.8 * 2 = 1.0, not 1.6.
Also, if we ignore the above for a moment and look at the last line:
0.6 * 2 = 1.2
This is wrong too. 0.6 * 2 = 0.C.
o i see thanks that makes sense
Given any hex number to binary, simply convert each hex digit to 4 binary bits, keeping the decimal point in the same position.
You can also think of e in 0.e as being in the 1/16th place. e in decimal is 14, so 0.e = 14/16 = 0.875
True. And that's fine for converting hex to decimal, however the OP is converting hex to binary, so your way would require much more work.
Hmmm, I thought I saw something about converting it to decimal also in the OP, but I guess I was wrong. :blushing:
I thought the same thing, at first. In fact, I had a reply similar to yours ready to post and decided to re-read the OP one last time, so I caught myself.
