Convert 50ml Honey Volume to Meters
  • Context: High School
  • Thread starter Thread starter Davidmb19
The discussion revolves around converting a volume measurement of honey from milliliters (mL) to cubic meters (m³). Participants explore the relationship between milliliters and cubic centimeters, and subsequently to cubic meters, while addressing unit conversion techniques.
  • One participant states that 1 mL is equivalent to 1 cm³.
  • Another participant attempts to set up a conversion equation, expressing 50 mL in terms of cubic centimeters and then converting to cubic meters.
  • A participant confirms the conversion process and emphasizes the importance of cubing the conversion factor when transitioning from centimeters to meters.
  • There is a suggestion that multiplying by a "useful expression for 1" is a helpful method for unit conversions.
  • Another participant proposes that substitution may be a clearer method for understanding the conversion process, highlighting a common misunderstanding regarding the interpretation of cm³.
  • A later reply clarifies that the final volume should be expressed in cubic meters (m³) rather than meters, which is a unit of length.
Participants generally agree on the conversion relationships between milliliters, cubic centimeters, and cubic meters. However, there is some debate regarding the best method for performing the conversion and the interpretation of units.
Some participants express uncertainty about the clarity of unit conversions and the potential for misinterpretation of cubic measurements.
Davidmb19
Using a graduated cylinder I measured the volume of honey to be 50ml. How do I convert this into meters for the volume to be in meters because it's currently in ml?
Mathematics news on Phys.org
Here's a start: ##1 mL=1 (cm)^3##
Ahh thank you. Given what you just said (just checking to be sure) this means that,
1ml= 1(cm)^3
50ml=x
x=50(cm)^3
in meters
x=50x10-^6 ?
Correct. As 1 cm is 1/100 meter (linear measurement), then for cubic measurements everything is cubed. 100^3 = 1 million or its reciprocal.
1ml= 1(cm)^3
50ml=x
x=50(cm)^3
in meters
x=50x10-^6 ?
Yes. The easiest way to get unit conversions right is by "multiplying by 1"
[tex]50cm^3 {(\frac{1m}{100cm})^3} = {50*10^{-6}m^3}[/tex]
I'll remember. Thanks, much appreciated XD.
Yeah, that trick made a big difference for me at the start of undergrad. That and learning to carry units along in all of my equations and manipulations -- really helped me to avoid (or find) errors. :smile:
While multiplying by the "useful expression for 1" is how I used to explain that method of unit conversion,
I think substitution is better:
##50mL=50(1 (cm)^3))=50(1 (10^{-2} m)^3))=50(10^{-6} m^3)##
Probably the biggest problem is that many students incorrectly interpret ##cm^3## as ##c(m^3)=(10^{-2})(m^3)##.
1ml= 1(cm)^3
50ml=x
x=50(cm)^3
in meters
x=50x10-^6 ?
The volume won't be in meters, which is a measure of length -- it will be in cubic meters, or m3.
  • · Replies 18 ·
  • · Replies 20 ·
