Convert horsepower to duck power
48 replies · 197K views · last reply
DingusDev42
Okay, so maybe this is the wrong forum. I'm here as a last resort, I've been on 4Chan and ask websites for three hours just looking for ideas, or God willing, some real data.
I've been tasked by a friend to convert horse power into duck power. It sounded easy at first but I'm stuck. I've barely gathered any data and I can't think of how to move on.
1 Horsepower = ~750 Watts or 550 foot-pounds per second
The only lead have is that a duck in DnD has a strength attribute of 3, but I don't play DnD so I don't know if that means anything in real world terms.
It's okay if some logical reaches are made, considering the silly nature of this project. If you have an idea concerning where I should look, like a different forum or website, I'm all ears.
Minimum cost of transport for a swimming duck is 5.77 kcal/kg per km. (https://books.google.com/books?id=U64JafOXDWkC&pg=PA133&lpg=PA133&dq=metabolic+rate+of+ducks&source=bl&ots=BxgPCY3HSm&sig=d7ZqsNDQOO1jYkx4WW-Jz5AXq7Q&hl=en&sa=X&ved=0ahUKEwjizJfLy5PQAhUFQyYKHXe6Cd44ChDoAQgaMAA#v=onepage&q=metabolic rate of ducks&f=false) if the average weight of a duck is 2 kg, that's about 2.8 kcal per kilometer. if a duck can swim at .7 m/s, converting that to km/s gives .0007km/s. Now mulitply this to the cost of transport and you get 5.77*.0007/2 ##\approx## .00202 kcal/s.
I shall leave the dimensional analysis for finding the conversion factor up to you.
Power would be the ability to do work continuously - if you want DnD appropriate stuff, then compare the stats, probably for dragging or carrying a load.
A light load for a light horse is up to 150 pounds; a medium load, 151–300 pounds; and a heavy load, 301–450 pounds. A light horse can drag 2,250 pounds.
http://www.dandwiki.com/wiki/SRD:Light_Horse
... no stats for a duck (avian) and animals do not have the strength, etc type stats that PC's do.
You'd have to look for closest likely creature: http://www.giantitp.com/forums/showthread.php?275156-Stats-for-birds
Phyiscally, you will want to figure out how "horsepower" is defined in terms of work done by horses, and then find data for what ducks can do.
Consider: Are the ducks walking, swimming, or flying?
Ultimately the conversion will depend on what you want to do with it - why is it relevant?
@Jamison Lahman : wow - just... wow.
8.45W or very roughly 1% of 1hp for swimming.
I don't know any references researching duck power, but Monty Python provides some clues about swallows. Apparently, two European swallows should be able to carry a coconut together, using a string held under the dorsal guiding feathers.
No research cited, as these observations were made in medieval times. But if you assume a diameter and drag coefficient for the coconut, and a cruising speed, you can at least estimate the aerodynamic power. I'd have to think about the power required to carry the weight.
Solving the point slope equation for humans and horses, where:
The average human weighs 137 lbs, and can sustain 0.1 hp, and the average horse weighs 1100 lbs, and obviously can sustain 1.0 hp​
It is quite clear what the average duck, weighing 7.5 lbs, is capable of.
The answer is a tad less than Jamison Lahman's solution, as his duck was swimming, and mine, was not.
[references available upon request]
Consider references requested ... all the time, every time.
In a scientific forum, citations are always requested, by default, for any claim.
References:
Weight of an average horse: 1100 lb
https://www.reference.com/pets-animals/much-average-horse-weigh-289a0e909645d02d
weight of an average duck: 7.5 lb = 3.40 kg
https://answers.yahoo.com/question/index?qid=20100617221317AAVc6Qn
weight of an average human: 62 kg = 136.69 lb
http://link.springer.com/article/10.1186/1471-2458-12-439
average hp of 1 human = 0.1 hp
https://en.wikipedia.org/wiki/Horsepower
Also: Kleiber's Law
https://en.wikipedia.org/wiki/Kleiber's_law
Kleiber's law, named after Max Kleiber's biological work in the early 1930s, is the observation that, for the vast majority of animals, an animal's metabolic rate scales to the ¾ power of the animal's mass. Symbolically: if q0 is the animal's metabolic rate, and M the animal's mass, then Kleiber's law states that q0 ~ M¾. Thus a cat, having a mass 100 times that of a mouse, will have a metabolism roughly 32 times greater than that of a mouse. ​
weight ratio horse to duck = 146 2/3
(146 2/3)^(3/4)=42.1
1/42.1 = 0.0238 hp [duck]
This is roughly 3 times my calculation.
Resulting in the answer of :eek: 42, to within 1 part in 3000.
@DaveC426913 Yup. Douglas Adams is prize winning physicist. Or is that psychic? 42 is the answer to everything as I see you realize fully.
Wow, you guys are great. You may be interested to know that I reached out to /tg/ on 4Chan. I figured they'd have some input since I tried using DnD stats. They all came up with some really interesting math and the answers ranged between 25 and 60 duck power per horsepower, with some outliers.
42 isn't the answer to everything like everyone thinks, it's the answer to the ultimate question of life, the universe and everything. But no one knows what the ultimate question of life, the universe and everything is. Which is good too, because no one world can know both the question and the answer, because knowing both causes the universe to cease to exist.
jim mcnamara said:
@OmCheeto if nothing else you get high marks for persistence! :woot:
I initially considered modeling a spherical duck versus a spherical horse, but things got a bit complicated, so I just googled stuff, and did a few calculations.
I was also curious how to verify the output of ducks, so I imagined 42 ducks in a tug of war contest with a horse. Googling was not my friend.
But I did find a horse which won a tug of war contest against 50 men[ref], so this leads me to believe that a tug of war contest may not be the best test of power output, as 10 men should have been the horses equal.
Excellent! I was just tabulating the results so far. I'll add those two numbers, and one more for good luck:
Code:
hp/dp  dp/hp
0.0070  143  Interpolation by horse, human, duck, point slope method
0.0073  137  Fine structure constant[why not]
0.0133   75  Jamison Lahman's reference. [see note 1]
0.0167   60  4Chan upper range
0.0238   42  Kleiber's Law
0.0400   25  4Chan lower range
note 1: Interestingly, his reference listed Kleiber's name and is dated 1961. The wiki entry dates his work to the 30's. Which meant he was doing duck power experiments for at least 30 years. Now that's persistence.
Max Kleiber [wikipedia]
What do you mean? An African or European swallow?
... the theory is that it will be instantly be replaced by something even more inexplicable. There is another theory that says this has already happened. Perhaps I'll have another glass of whiskey ... yes, that seems more likely.
Doesn't seem to matter:
http://style.org/unladenswallow/
All said and done, then, a duck should be able to crank out 17 watts if you could get it to turn a wheel somehow, maybe a duck adapted bicycle pedal affair hooked to an alternator or generator. Train it with tidbits till it gets the hang of it and do a dynamo check on the beast:)
Oh. I didn't see that you inverted 42.1 to get the decimal.
My answer actually took your .0238 and inverted it, but I got 42.015.
Given that I know of no fractional ducks, I believe that your inference that 42 is close enough to the answer, makes me trust that Mr. Adams was correct.
This all seems pretty much a waste of time, particularly when we observe that 1 hp has little or no bearing on the power output from any particular horse at any particular instant.
Its not a waste of time for those entertained by it. Waste, is a relative term. While i see no use for my old aluminum cans and foil, i would throw them in the trash, to someone who uses aluminum for something such as making aluminum cast models, they would find my actions wasteful. Do refer to the old adage, one man's trash, is another's treasure.
DingusDev42 said:
...no one knows what the ultimate question of life, the universe and everything is...
Yes they do. Marvin read it off, in the last book.
What do you get when you multiply six by nine.
Alright this thread is hilarious :biggrin:
Since Ducks probably expend the most energy during flight, I would approach the "Duck Power" problem by estimating how much energy they expend during flight. We will for the moment, assume 1 hp = 745 W.
  1. It is stated by Ducks.org that an average size hen mallard duck will burn approximately 1.8 million calories during a 1,500 mile flight from Saskatchewan to Louisiana
  2. It is also stated by Ducks.org that most waterfowl species average about 50 mph during flight
  3. Based on this speed, a 1,500 mile flight takes a duck about 30 hours flight time
  4. 1.8 million calories expended in 30 hours calculates to 1 Duck Power = 69.8 W (0.094 hp)
Worked calculation estimating a Duck Power unit from energy burned in flight: 1 cal = 4.187 J, hp = 745.7 W, flight distance 1500 mi, flight speed 50 mi/hr, flight time 30 hr, 1.8 million cal, giving Duck_Power = 69.78 W = 0.094 hp.
This seems like a hasty assumption. I would imagine ducks have optimized their flight capabilities as well as the fact they are likely going to try to expend the fewest calories during a 1,500mi flight. An analogy would be how humans expend more calories in water than on land. I am not a physiologist, but something to think about nonetheless.
See for yourself:
http://www.ducks.org/conservation/waterfowl-research-science/understanding-waterfowl-fat-is-fit
Fat stores accumulated prior to and during migration come in handy because flight is among the most energetically costly activities that waterfowl undertake. Ducks burn 12 times more energy in flight than at rest. The energetic costs of flying are proportional to the size of the bird—the bigger the bird, the more energy required.
I find it troubling that duckpower is equal to humanpower. I am not sure what to make of this revelation.
Indeed, although per Wikipedia trained human athletes can sustain ~3.7 duck-power for a period of several hours ;-)
Wikipedia.org said:
When considering human-powered equipment, a healthy human can produce about 1.2 hp briefly (see orders of magnitude) and sustain about 0.1 hp (74.57 W) indefinitely; trained athletes can manage up to about 2.5 hp (1.85 kW) briefly and 0.35 hp (260 W) for a period of several hours.
Hmmmm. It does not seem like horsepower is defined as the maximum energy output of a horse, but rather the average output over a few hours of turning a mill wheel. Also, if a human can exceed a humanpower by an order of magnitude briefly, it seems reasonable to speculate so too could a horse and a duck. Therefore, I reason a duckpower should be roughly an order of magnitude less than the maximum output, resulting in an answer closer to mine and @OmCheeto's.
P.S. if anyone has any ducks, I implore you to make a to-scale mill wheel and see how many turns the duck is capable of in an hour.
The to-scale mill wheel is the easy part, in fact I might even volunteer; assuming you train the ducks.
