Converting angles in to degree to angles in radians
To convert angles from degrees to radians, the key formula is to multiply by the conversion factor 2π radians/360 degrees. For example, to convert 15°, 60°, and 80° into radians, one would multiply each degree value by this factor. This method allows for the cancellation of units, simplifying the calculation. Understanding how to manipulate the conversion factor is crucial for accurate results. Mastery of unit conversions is essential for success in mathematics and related fields.
tomsdubs
Convert the following angles in degree to angles in radians:
15° 60° 80°
Now i know that 2 ti c = 360°
And that 6.28 c = 360°
I just can't quite get my head around it, what calculation should i be doing?
2*pi*c=360 degrees, so c=360/(2pi)=180/pi, which is the number of degrees in a radian. So if there are 180/pi degrees per radian, there are 15 degrees per _____ radians.
15° 60° 80°
For any units conversions, I like to use the method of multiplying by "1".
The trick is to figure out the best form of "1", and be sure to carry units along with the calculations, cancelling units as appropriate.
So the "1" I would use for these converstions, from degrees to radians, would be:
1 = \frac{2 \pi radians}{360 degrees}
Then all you have to do to get an angle in radians from an angle in degrees, is to multiply the number by the "1" above, and cancel out any units that are on both top and bottom.
If you were changing units the other way, do you see how you would flip the fraction to do it?
Carrying units along in calculations was a huge trick that I luckily learned early in my first year at university.
  • · Replies 17 ·
