How do I convert 1.2atm to N/m^2 when solving for gas work?
  • Thread starter Thread starter HazyMan
    thermodynamics
To convert 1.2 atm to N/m², multiply 1.2 by 1,013 x 10^5 N/m², resulting in 1,215,600 N/m². The isobaric expansion work formula W = p(V2 - V1) requires pressure in the same unit system, hence the conversion is necessary. While calculators can simplify this process, manual multiplication is straightforward. Understanding the conversion is crucial for solving gas work problems accurately. The discussion emphasizes the importance of unit consistency in physics calculations.
HazyMan
<Moderator's note: Moved from a technical forum and thus no template.>
My homework says: Gas with a volume of 0.004m^3 is heated with a steady pressure of 1,2atm until the volume turns into 0.006m^3. Calculate the work that the gas produces (Given: 1atm=1,013x10^5 N/m^2).
I used the Isobaric Expansion Work formula W=p(V2-V1) and i managed to get to W=1,2atm x 0.002m^3, however atm and m^3 are not in the same system. I am trying to convert 1.2atm into N/m^2 but i can't find anything on the internet, so i came here asking for help. Where can i find a guide to do this conversion? Is it even possible, is it needed to convert to Pa instead?
1 Pa = 1 N/m2
1 atm = 1.01325 bar
1 bar = 105 Pa
Likes DrClaude
I am trying to convert atm into N/m^2
It looks to me as if you had answered your own question before asking it.
[Personally, being an ancient U.S. relic, I'd have taken 14.7 pounds per square inch, converted pounds to kilograms-force to Newtons and square inches to square meters]
Likes DrClaude
i'm trying to convert 1,2atm into N/m^2. not 1atm.
Most calculators give you the ability to multiply by 1,2
i know, i'd just like to do it manually.
Code:
   1,013 x 10^5
x  1,2
   1,013
   + 2026
   1,2156 x 10^5
Long multiplication by 1,2 is not much harder than a calculator.
Likes HazyMan
jbriggs444 said:
Code:
   1,013 x 10^5
x  1,2
   1,013
   + 2026
   1,2156 x 10^5
Long multiplication by 1.2 is not much harder than a calculator.
Thanks.
