Converting between a known and unknown temperature scale
10 replies · 12K views · last reply
BOAS
On a Temperature scale, the ice point is 25.6°I and the steam point is 155°I. If the temperature reads 66.6°I what is the equivalent in °C?
25.6°I = 0°C
155°I = 100°C
1°I = 5/647 of the interval between boiling and freezing.
1C° = 647/500 I°
1I° = 500/647C°
66.6°I = 51.5°C
I arrive at this answer but I'm not convinced I've done this correctly. When changing from faranheit to celsius for example, I have to subtract the offset from zero...
So should my answer actually be 51.5 - 25.6 °C?
I'd really appreciate some help,
thanks!
66.6°I = 51.5°C
That's not correct. And I don't understand where you get fractions like 5/647.
I think that an easier way to do the problem is to try to solve for the formula
a T_I + b = T_C,
where ##T_I## is the temperature in °I and ##T_C## is the temperature in °C. Using the data you have, that gives you two equations for two unknowns (##a## and ##b##).
After recalculating a few things, I find that
BOAS said:
1C° = 647/500 I°
1I° = 500/647C°
is correct. The problem is the shifting of the scale. Neither
BOAS said:
66.6°I = 51.5°C
nor
are correct.
Note that Dr. Claude is using the fact that the relation between the two temperature scales is linear- one degree celsius converts to the same number of degrees Farenheit, and vice-versa, at any temperature.
a T_I + b = T_C,
When converting between faranheit and celsius, we say that 1°F = 1/180 of the interval between the boiling and freezing point.
Compared to the 1/100 of the interval that 1°C expresses.
9/5 of a degree faranheit is equivalent to 1 degrees celsius.
It was this method I was trying to use that gave me those strange fractions...
I haven't seen the method you are talking about before, please could you apply it to something so I can see what you mean?
Right. It is implicit in the problem. Good of you for pointing this out.
nor
are correct.
Ok,
I think this makes sense to me, I hope it does to you.
°C = ([°I] - 25.6) x 500/647
giving me the answer that 66.6°I = 31.7°C
Edit: You got the correct answer in the previous post while I was typing the following. I'll leave it in case someone else has a similar problem.
Lets say we want to rederive the conversion from Fahrenheit to celsius. Take
freezing point: 32 °F = 0 °C
boiling point: 212 °F = 100 °C
We look for an equation of the type
a T_F + b = T_C
For the values above
a \times 32 + b = 0 \\
a \times 212 + b = 100
From the first equation, we have ##b = -32 a##. Using that in the second equation, we get
212 a - 32 a = 100 \Rightarrow a = \frac{100}{180} = \frac{5}{9}
and ##b = -160 / 9##. So
\frac{5}{9} T_F - \frac{160}{9} = T_C
I realize now that this is not the usual formula. You should therefore try it yourself using
\left( T_F + a \right) \times b = T_C
to get the factors you know. You can then do the same for your problem.
BOAS said:
Ok,
Correct!
This is a detailed explanation on how to solve this problem and solve any problem based on temperature scale conversion. It's very easy. Hope it helps. I AM THE ONE WHO KNOCKS.
