Converting binomial theorem sigma notation to expanded form
69 replies · 19K views
Mentallic said:
Why did you get stuck? That's exactly what it should be!
So now we have
[tex]\int{f(x)dx}=\sum_{k=0}^{n}{^n}C_kx\cdot \left(x^2\right)^k[/tex]
And since x is independent of k, it can move out the front of the summation, so we have
[tex]x\sum_{k=0}^{n}{^n}C_k\left(x^2\right)^k1^{n-k}[/tex]
And now apply the formula to convert it into a binomial. And since you need to find f(1), take the derivative of both sides to get the expression for f(x).
If i convert it into binomial, i get
[tex]x.(x^2+1)^n[/tex]
I substitute the value 1 and i get
[tex]2^n[/tex]
But then how i would find out the derivative??
Do i have to first take the derivative and substitute the value 1?
Good! :smile:
Yep! :approve:
Yep, that's what I meant by
:smile:
You're nearly there!
Thanks! :smile:
I think that this time i am right.
I took the derivative and found it to be
[tex]2nx(x^2+1)^{n-1}[/tex]
Now i substituted the value 1 and i got:-
[tex]2n.2^{n-1}[/tex]
Right...?
No, not quite.
What you have is not the derivative of [itex]x.(x^2+1)^n[/itex].
You need to apply the so called product rule.
That is: (u v)' = u' v + u v'
And you have to apply the so called chain rule.
That is: (u(v))' = u'(v) v'
Are you familiar with those rules?
I am not familiar with the product rule but when i calculated the derivative on Wolfram, it was the same as i got? :confused:
Then you need to either go back and run over it again or take our word for it :wink:
Try applying the product rule, let [tex]u=x[/tex] and [tex]v=(x^2+1)^n[/tex]
I again tried to calculate the derivative and got:-
[tex]2nx^2(x^2+1)^{n-1}+(x^2+1)^n[/tex]
Right...?
Now i substitute the value 1 and i get:-
[tex]2^n(1+n)[/tex]
Am i right this time?
I like Serena said:
Right... and we're done! :cool:
Thanks for reply! :smile:
I have more questions.
The question is:-
[tex]\sum_{k=1}^n \frac{{}^nC_k}{k+2}[/tex]
Can you provide me some hints to start? :smile:
(Please don't think that i am trying to solve my homework, it's not a homework question, it is from a test paper, i am only trying to get a strong hold on binomial theorem and Calculus :frown:)
Looks like a combination of the previous 2 problems. :smile:
The boundary k=1 is one off. You need to correct that.
And you can define a function of x, such that the denominator disappears when you take the derivative.
I thought of that but how should i define a function of x? Like in previous question you took x2k, so what should i take here? :confused:
Last time we chose x2k because the integral of it caused us to cancel the factor 2k+1. This time we will be taking the derivative and what n must be chosen such that when we take the derivative of xn, it cancels out the factor [tex]\frac{1}{k+2}[/tex]
And by the way, you are always allowed to check your answer, so whatever you choose, take the derivative to see what happens :wink:
I tried solving it, please tell me if i am wrong somewhere:-
Define it as a function of x and differentiate it, i.e.
[tex]f(x)=\sum_{k=1}^n \frac{{}^nC_k}{k+2}x^{k+2}[/tex]
I mould it so that it is in the form where k starts from 0, i.e
[tex]f(x)=\sum_{k=0}^n \frac{{}^nc_k}{k+2}-\frac{{}^nc_0x^2}{2}[/tex]
Then i differentiated it and i get:-
[tex]\frac{d}{dx}(f(x))=(\sum_{k=0}^n{}^nC_kx^{k+1})-{}^nC_0x[/tex]
Converting it to binomial form:-
[tex]\frac{d}{dx}(f(x))=x(x+1)^n-x[/tex]
Now what should be the next step? :confused:
Should the next step be integration?
[tex]f(x)=\sum_{k=0}^n \frac{{}^nc_k}{k+2}x^{k+2}-\frac{{}^nc_0x^2}{2}[/tex]
Beautifully done so far. You just accidentally forgot to write down the red part.
Well yes, of course it's time for integration since your ultimate goal is to calculate f(1) :smile:
Thanks Mentallic and I Like Serena! :smile:
I think i have got it right.
Integrating [itex]x(x+1)^n-x[/itex], i get:-
[tex]\frac{x(x+1)^{n+1}}{n+1}-\frac{(x+1)^{n+2}}{(n+1)(n+2)}[/tex]
Substituting the value 1, i get:-
[tex]\frac{n.2^{n+1}}{(n+1)(n+2)}[/tex]
Am i right...?
Oops! Sorry..
Almost. ;)
First, it seems that you forgot to integrate the loose term "x".
And when you integrate, there is a slight problem called the integration constant.
That is, you need to add the as yet unknown constant C to the result of the integration.
Then you need to fill in a value for n and see how it works out.
From the result you can determine the value of C.
I like Serena said:
Almost. ;)
I didn't get how to find out the constant? :confused:
Where i forgot to integrate "x"?
You had to subtract the k=0 term, which ended up being just "x".
I don't see it back in your integrated result.
Let me explain with an example.
Suppose you have the function f(x)=x2 + 3
Now you know that f(0)=3 don't you?
Taking the derivative we get f'(x)=2x.
Taking the integral again we get [itex]\int f'(x)dx = x<sup>2</sup> + C[/itex]
(This is called an indefinite integral, since the boundaries were not given.)
As you can see the result is not equal to the original function - we lost the '3' in the process.
But since we know that f(0)=3, we can deduce that the integration constant C must be 3.
In which step should i substitute zero to get the constant? :confused:
I'm assuming you mean in my example.
(It's slightly different for the current problem.)
In my example we have as input [itex]f(x) = \int f'(x) dx = x^2 + C[/itex] and f(0)=3.
We want to find f(x).
Filling in x=0 gives: [itex]f(0) = 0^2 + C = 3[/itex].
So C = 3.
So C = 3.
I got what you said. :smile:
But i am asking in which step should i put x=0?
Should i put x=0 during the integration step? :confused:
I don't understand your question.
Afaik I have explicitly stated where you put x=0.
I only could have added as a last step that the conclusion is that f(x)=x2 + 3.
Pranav-Arora said:
i think the constant is zero. :confused:
Now I really don't understand you. :confused:
Which constant?
In which formula?
In which post?
Why would it be zero?
Which constant?
In which formula?
In which post?
You gave an example that f(x)=x2+3.
And you said that f(0)=3, i.e you substituted the value 0 at the place of x. Right..?
Now that 3 is our integration constant, we can substitute 3 in [itex]\int f'(x)=x^2+C[/itex] at the place of C.
I did the same in my question. I substituted 0 in f(x), i.e i substituted 0 in:-
So i got f(0)=0. Therefore integration constant is 0.
Did you get me now? :confused:
Yes, I more or less get what you did, but it is not right.Let's take it a couple of steps back.
You had:
[itex]f'(x) = x(x+1)^n \color{red}{\textbf{- x}}[/itex]
You integrated this wonderfully, but you forgot the "[itex]\color{red}{\textbf{- x}}[/itex]" I just marked.
So you should have:
[tex]f(x) = \int f'(x)dx =\frac{x(x+1)^{n+1}}{n+1}-\frac{(x+1)^{n+2}}{(n+1)(n+2)} - \frac {x^2} 2 + C[/tex]
Now you need to determine the integration constant C using f(0) = 0, but C is not zero!
You had:
So you should have:
So then what's the C, i don't seem to find any other way to find C. :confused:
What do you get if you fill in x=0 in this formula?
[tex]f(x) = \frac{x(x+1)^{n+1}}{n+1}-\frac{(x+1)^{n+2}}{(n+1)(n+2)} - \frac {x^2} 2 + C[/tex]
