Converting MPa·mm1/2 to MPa.m1/2: A Scientific Approach
The discussion revolves around converting the unit of measurement from MPa·mm1/2 to MPa·m1/2. Participants are exploring the implications of unit conversion and the correctness of the exponent used in the original measurement.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants present different methods for conversion, questioning the validity of their calculations. Some express uncertainty about the exponent, while others confirm its correctness and discuss the implications of unit conversion on numerical values.
The discussion is active, with participants providing insights into the conversion process and questioning assumptions about the units involved. Some guidance has been offered regarding the expected numerical outcome after conversion, but no consensus has been reached on the correct approach.
There is a focus on understanding the significance of the units involved, with participants clarifying the meanings of MPa and mm. The original poster's calculations are under scrutiny, and the potential impact of converting millimeters to meters is being discussed.
Dave_
I need to convert 12.5 MPa·mm1/2 into MPa.m1/2.
I am unsure on how to do this, my two guesses are as follows:
1. (12.5) / ( 1 / 10001/2) = 395.28 MPa.m1/2
2. (12.5) / (12.5 / 10001/2) = 31.62 MPa.m1/2
Is either of those correct? Thanks!
Dear Dave,
is the 1/2 exponent correct? Isn't it -2?
Best regards!
Segala said:
Dear Dave,
Best regards!
I've just doubled checked and the 1/2 exponent is correct, the value is a material constant. Is it possible to convert it into MPa.m1/2? Thanks.
It should be possible.
(MPa = "MegaPascal"?)
(mm = "millimeter"?)
(If those [itex]\uparrow[/itex] are the units then) Your original two answers shouldn't be right, because you would expect the answer to be significantly smaller, right?
(Converting mm to m would decrease the numerical value)
Ahh I see, so should I be calculating (12.5 / 10001/2) = 0.395 MPa.m1/2?
Thanks!
Thanks!
Yeah
The meticulous method of figuring it out would be:
[itex]12.5 MPa(mm)^{1/2}=12.5MPa(\frac{m}{1000})^{1/2}=\frac{12.5MPa\cdot m^{1/2}}{1000^{1/2}}=0.395MPa\cdot m^{1/2}[/itex]
Dear Dave,
this is new to me! What is this unit used for?
Best regards!
  • · Replies 0 ·
