Converting parts per million (ppm) and mol of ions
  • Thread starter Thread starter ScienceNewb
    Ions parts Per
The discussion focuses on converting parts per million (ppm) and molarity (M) of various ions in solutions, specifically fluoride in water, calcium hydroxide (Ca(OH)2), and potassium sulfate (K2SO4). The calculations involve determining the amount of fluoride in 1 gram of water at a concentration of 0.90 ppm, which results in approximately 4.74 x 10-8 moles of fluoride. Additionally, the conversion of 0.00036M of Ca(OH)2 to ppm is discussed, along with the molar mass of K2SO4 being approximately 174 g/mol. The importance of chewing antacid tablets before swallowing is also questioned, highlighting the need for proper dissolution for effective absorption.
  • Understanding of ppm (parts per million) and its application in solution concentration
  • Knowledge of molarity (M) and how to convert between molarity and ppm
  • Familiarity with molar mass calculations for compounds like Ca(OH)2 and K2SO4
  • Basic principles of stoichiometry and Avogadro's number
  • Learn how to convert molarity to ppm for various compounds
  • Study the implications of fluoride concentration in drinking water
  • Explore the role of antacids in digestion and the importance of their physical form
  • Investigate the calculation of ion concentrations in different volumes of solutions
Chemistry students, environmental scientists, and health professionals interested in water quality and the effects of ion concentrations in solutions.
ScienceNewb
1. Fluorine compounds are added to water, the concentration being 0.90 ppm.
a. What amount of fluoride present 1.0g of water?
Solution- (just need to know what the number mean)
Divided 0.90 pm by 1,000,000, which I assume is the grams of substance per kilogram?
Then divided that number by fluorines molar mass (19) to get the answer of 4.7x10^-8
b. How much fluoride ions would you swallow if you drank 200ml water?
2. Convert 0.00036M (molarity) of Ca(OH)2 to ppm
Solution- I found the molar mass of the compound being ~74
3. For 0.20M of K2SO4, calculate mol of K+ ions, Sulfate ions and oxygen atoms
Solution - Molar mass I found to be ~174
4. Why should antacid tables be chewed before being swallowed?
5. Find concentration of vitamin c in g L^-1 when 40mg/100ml and do same for carbonhydrate at 8.5g/100ml
Solution- I'm guessing I just divided 40mg/100ml and 8.5g/0.1L but not sure if this makes sense?
Any help would be appreciated...
For #1, ppm means parts per million. If fluoride is added to water to make a concentration of .9 ppm, that means that there are .9g of fluoride per million grams of water. The amount of fluoride in 1 g. of water would be .9/1,000,000 * 1 g.
For #4, what would be the effect of chewing up antacid tablets (not tables) before swallowing them?
Hey thanks!
Could you help me with the 200ml question? I figured out all the rest
I'm not sure what you mean by "how much fluoride ions." This is ambiguous, as it could mean the actual number of fluoride ions or it could be the volume. If you're interested in the volume, the concentration of fluoride ion is .9/1,000,000, so multiply that ratio by the volume of water, 200 ml, to get the volume of fluoride ion.
I think it means the number of ions, the answer at the back is 5.7 times 10^18
From something you said in the first post, the .9 PPM is the concentration by mass. PPM is NOT the number of grams per kg. That would be parts per thousand.
1 PPM would be 1 microgram (one millionth of a gram) of whatever in a gram of the substance it's in.
When you did problem 1a you had .9/1,000,000 * 1 g * 1 mole/19 g = 4.74 x 10-8 moles of Fluoride.
To get the number of molecules, multiply the number of moles by Avogadro's number, which IIRC is 6.022 x 1023.
That will give you the number of Fl molecules in 1 g. of fluoridated water. Take that number an multiply by the number of grams of water in 200 ml.
It's been a very long while since I've done these calculations, so I'm a little rusty, but I don't think I'm steering you wrong.
As a tip, be sure to put units in - otherwise it's very easy to get an answer that's meaningless.
Volume? No, it is either number of moles or number of ions.
methods
39K
