Fortran Can Fortran handle cross-referencing on a large array of data?
  • Thread starter Thread starter zakynthos
    Fortran
The discussion revolves around the use of Fortran to perform a cross-referencing function on a large dataset organized in a four-column array with one million rows. The user seeks to match data in column A with column D by referencing values in columns B and C. They provide a VBA program that currently takes approximately 12.93 hours to run on a typical office PC. Feedback suggests that the algorithm is inefficient and that sorting the data before matching could significantly reduce the runtime to about one second. The user acknowledges this improvement and mentions switching to a VLOOKUP method, which has proven to be much faster. Despite this, there remains an interest in how the original VBA code could be translated into Fortran, indicating a desire to explore the capabilities of Fortran for handling such data processing tasks efficiently, potentially on high-performance computing systems like Fujitsu's K computer.
zakynthos
Hi, I've no knowledge of Fortran but am researching its (theoretical) use to perform a 'cross- referencing' function on data in a four column array of one million rows. The program matches data in column A to Column D by referencing the matching values in columns B and C.
Here's the program I'm using - could anyone convert this to Fortran and could this in, in practice, run on Fujitsu's K (10 teraflops) computer. If so, how long would it take the K to perform this task - I've calculated 12.93 hrs from tests on a typical office PC? With thanks.
Sub AddCodes()
Dim x As Long, LastRow As Long, UB As Long, BList As Variant
Const StartRow As Long = 1
LastRow = Cells(Rows.Count, "A").End(xlUp).Row
BList = Join(WorksheetFunction.Transpose(Cells(StartRow, "B").Resize(LastRow - StartRow + 1)), "/")
' Application.ScreenUpdating = False
For x = StartRow To LastRow
UB = UBound(Split(Split(BList, Cells(x, "C").Value)(0), "/"))
If UB >= 0 Then
With Cells(x, "D")
.Value = .Value & "," & Range("A1").Offset(UB).Value
If Left(.Value, 1) = "," Then .Value = Mid(.Value, 2)
.Interior.ColorIndex = 6
.Font.Bold = True
End With
End If
Next
Application.ScreenUpdating = True
End With
End Sub
Technology news on Phys.org
If it takes 12 hours on a PC your algorithm is hopelessly inefficient.
If you first sorted the table on the relevant columns and then did the matching, I would expect the run time to be of the order of 1 second not 12 hours.
Relational database operations are a good way to describe what you want to do, but they are often a bad way to actually do it.
Many thanks for your answer - your advice made me re-think the code and I've processed the array with vlookup instead and yes, you're right of course, about a second!
However, I'm still interested to knnow how my original code qwould translate into Fortran.
Thanks once again!
Learn If you want to write code for Python Machine learning, AI Statistics/data analysis Scientific research Web application servers Some microcontrollers JavaScript/Node JS/TypeScript Web sites Web application servers C# Games (Unity) Consumer applications (Windows) Business applications C++ Games (Unreal Engine) Operating systems, device drivers Microcontrollers/embedded systems Consumer applications (Linux) Some more tips: Do not learn C++ (or any other dialect of C) as a...
11K
26K
