Conveyor Speed / Distance calculations
The discussion focuses on calculating the gap between products transferring from one conveyor to another, specifically when products are moving at different speeds. Participants explore the necessary formulas and assumptions required to determine this gap, which is critical for system design.
  • One participant requests formulas for calculating the gap between products on conveyors moving at different speeds (x M/min and y M/min).
  • Another participant suggests a simplified approximation for the gap, assuming infinite product acceleration, and introduces variables for upstream speed (Vx), downstream speed (Vy), product length (L), and gap (G).
  • It is proposed that the time for the leading edge of the trailing product to contact the downstream conveyor can be calculated as t = L/Vx.
  • A participant calculates that if products are touching on the upstream conveyor, the time elapsed for the trailing product to contact the downstream conveyor is 12 seconds for a product width of 1m moving at 5m/min.
  • Another participant derives that the distance traveled by the leading edge of the leading product in time t is D = Vy * t.
  • There is a calculation presented where G = D - L, leading to a gap of 1m based on previous calculations.
  • Participants discuss the effective product length (Leff) and its relation to the gap, with one participant questioning the value of Vy and suggesting it must be 15 m/min.
  • There is a correction regarding the relationship between G, L, Vx, and Vy, with one participant asserting that G = L * (Vy / Vx) - L.
  • Another participant acknowledges confusion between D and G in earlier statements.
Participants generally agree on the formulas for calculating the gap and the relationships between the variables, but there are discrepancies regarding specific values and interpretations of the calculations. The discussion remains unresolved on some aspects, particularly the exact values of Vy and the implications of the assumptions made.
Limitations include assumptions about product acceleration and the definitions of product length versus effective product length, which may affect the calculations. The discussion does not resolve these assumptions.
Paulvp1968
I would like the formulae for calculating the distance created bewteen products transferring from one conveyor to another with a line of products moving at x M/min transferring onto a conveyor running y M/min. I need to be able to calculate what the gap will be between the products as this is critical to the design of the system. Urgent Help required PLEASE!
A very simplified approximation of product gap can be calculated if you assume infinite product acceleration from one conveyor to the other. If you are interested, I will help you find the solution, but I can't just give it to you.
Vx = upstream conveyor speed (m/min)
Vy = downstream conveyor speed (m/min)
L = product length (m)
G = gap between products (m)
Note that the units of the conveyor speed must be the same, and the gap units will be the same as those for the product length. Please use lower case "m" for metre.
Question:
If we assume that the product will accelerate from speed Vx to speed Vy at the instant that the leading edge of the product contacts conveyor y, and both products start fully on conveyor x, how much time will pass before the leading edge of the trailing product will contact conveyor y?
Assume both products are touching on conveyor x and based upon a product width of 1m moving at 5m/min then 12 seconds would be the time elapsed for the leading edge of the trailing product to contact conveyor y
FYI, I just changed the conveyor speed variables names to Vx and Vy.
So the time is obviously the product length divided by upstream speed Vx, or:
t = L/Vx
Jumping ahead, in the same time "t", the leading edge of the leading product will travel
a distance:
D = Vy * t
(Yes, I did just introduce variables t and D, but they are only temporary.)
Making sense?
I'm trying to move this along quickly...
G = ?
So D=2m so if i am understanding this G=D-L = 1m and that G is proportional to the original gap
Yes, G = D - L
Sorry, what was Vy? It must be 15 m/min, although I don't think you mentioned it.
You can either use L = actual product length (assuming no gap) or Leff = effective product length which is equal to product length + initial gap.
Yes, the final gap is proportional to product length (or effective product length).
So what is G in terms for L, Vx and Vy? I thought that was what you wanted.
So if G=D-L and we have the following form the calculations performed above
t= L/Vx = 0.2min
in the same time period "t" the leading edge of the product will move Vy*t to give product D = 10*0.2 = 2m. Therefore with G=D-L then G=2-1 so the gap between the products is 1m.
Calculated in terms for L, Vx and Vy, I can see the following G= Vy/VxL-L am I correct?
t= L/Vx = 0.2min
Not quite, it should be:
or more simply:
G = L * [(Vy / Vx) - 1]
To check:
If Vy = Vx, G should be 0.
Looks like I got D and G mixed up previously when I indicated that Vy = 15 m/min (I was wrong).
Many thanks for your asistance. Much appreciated.
10K
