How to Correctly Convolve x[n] with a Unit Step Function?
  • Thread starter Thread starter redundant6939
    Convolution Unit
To convolve x[n] with the unit step function h[n] = u[n], the correct approach involves using the convolution definition y[n] = ∑ (k = -∞ to +∞) x[k] h[n-k]. Initial attempts to flip and shift h[n] resulted in all zeros, indicating a misunderstanding of the convolution process. The correct convolution yields a non-zero sequence based on the values of x[n], represented as a sum of shifted and scaled impulses. The graphical method can aid in visualizing this process, demonstrating how to align and sum the contributions from x[n]. Understanding these principles is crucial for accurately performing convolution with unit step functions.
redundant6939
Find convolution of x[n] (graph in attachment) and h[n] where h[n] = u[n]
- flipped the h[n] to have h[-n]
- moved to the left once (h[-1-n]) to align
- multiplied h and x and it gives me all zeros
Is this correct or I'm missing something?
I don't know about your graphical algorithm but if you use the definition
y[n] = x[n]*h[n] = ∑ (k = -∞ to +∞) x[k] h[n-k]
then I get a non-zero sequence of numbers:
a+0.5, b+0.5, c+0.5, c+0.5, d+0.5, d+0.5, d+ 0.5, ...
wher a, b , c, and d are positive integers for you to find.
Just think x(n) as sum of shifted and scaled impulses . Since you know the convolution of a signal h(n) with shifted impulse will be shifted h(n) and then you add them .
