Copy C++ string to C-string with exact length allocation
  • Topic: C/C++
  • Thread starter Thread starter yungman
    C++ Strings
118 replies · 15K views · last reply
I just finish my notes on stepping through the program and to show description, cost and units have different addresses for the 3 overload constructors. I attached the page of my notes. This is getting more complicated, I really have to stop, going through it to see how constructors are in action.
Seems like Constructor is NOT being run right at the beginning of the program like Distructor that run right before the end of the program whether it's called in main() or not. Constructor has to be called in the main() before it's executed. Like in the program that doesn't go to the first Constructor#1 until the line invItem item1, invItem item2 for Constructor#2 and invItem item3 for Constructor#3.
Mark44 said:
A common style for class member names is m_name
Going further, it is good to do this to separate members from methods. So you might have member m_radius in your class Circle, but also methods Radius, Diameter and Area. Or possibly getRadius, getDiameter and getArea. Whet you don't want is Diameter, getArea, get_the_circumference and if you want the radius, you need to know to access the member directly.
That makes the programmer's life easier. And the programmer might be Future You.
It's also a good idea to make m_radius private. That way that when you decide that m_diameter would be a better idea, you only need to make that change within the class. Code that merely uses that class remains unchanged.
Thanks Mark for the reply.
I have a question. From looking at breakpoints through the program, I notice the values of description, &cost and &units disappear RIGHT AFTER stepping beyond the Constructor#1 as shown. I open the Immediate Window and print them out right after the first breakpoint to line 10 in invItem.h file. I show I have the addresses of all 3 in the first picture.
But I step to the second break point, all the addresses are gone:
The program is not done with Constructor#1 yet, why all the 3 are "undefined" already?
The reason I want to look at is all 3 were initialized to " ", 0.00 and 0 when initialized. Then the program should overwrite to "Hammer", 6.95 and 12. I never get to verify that.
Thanks Mark.
No, the program is done with Constructor #1. That's what happened in the line
InvItem item1;
In the first screen shot, the code is executing within the default (i.e., no parameter) constructor InvItem(), so the names description, cost, and units are within scope.
In the second screen shot, the code is executing in main(), and the default InvItem() constructor has already created an object, the one named item1. The class members description, cost, and units are private, so aren't accessible outside the class (that is, outside the class member functions). That's why these identifiers don't show up any more.
InvItem item1;
I see, it's private, so the moment it leaves Constructor#1, I cannot see it anymore.
But even when I was in the constructor, I still cannot see the new values, maybe I have been trapping them in the wrong place. But at least I proved the address already to show I have 3 sets of overload variables.
Thanks for you reply,
Ha ha, do you know of anyway to step BACKWARD in debugger?! You ever encounter you do F11 and you say "ooops", you regret having that itchy finger and you wish you can just go back one step? I have to hit shift-F5 and start all over again so many times!
I know you can take the program back by hovering the mouse on the line and you'll see a little arrow and you click, you force the program to go back. BUT the damage is done, values are changed. I am talking about reversing the direction and restore the execution as if it never execute...Am I pushing my luck?
Thanks
I think maybe you are confused about what the class is. You can think of it like a blueprint or schematic.
It's only when you create an object/instance of them (construct) that an object/instance of the class exists with the variables in memory. A constructor is the first function that is called when you make one. And each one you make is a different one with different memory.
So it's not because you use a different constructor that description is different, it's because you made a new and different InvItem. If you made 3 different instances using the same constructor, they would of course still have different memory/variable instances. Just like 3 different houses use different wooden beams, even though the blueprint just shows one.
Thanks for reminding me. I read and even put in my notes Class is the blueprint only. But when dealing with codes, it quickly becomes just an external function...like a function call to a function outside of the project.
Like I traced the whole project step by step, it actually go from main() to invItem.h, follow the code, execute and return back to main(), then call the second and third Constructors, then call member function() to output the values to the CRT. It's just like an external function.
I honestly don't see the Class object is the blueprint. How is the invItem.h header file the blueprint of the whole program? Can you explain what in the invItem.h the blueprint of the project?
I know you are right, I just can't see it.
Thanks
The class, class InvItem { ... }; is like a blueprint for an InvItem. It is not until one of those is constructed that an object exists. The analogy was meant to help you understand the difference between an object and a class.
So invItem is a Class, the blue print of allocating memory using description and two variables cost and units. It is a blue print until the program say invItem item1 than item1 is the object being created. I see now invItem Class is NOT the blueprint of the program, just one of the structure like item1, 2 or 3.
How is this different from say an external function having a structure
C++:
struct invItem
char* desc = new char[L];
double cost;
int unit;
I know there are lot more detail, I am not saying they are the same. But you get my point that the external structure is not a blue print, but you can make it work the same way.
Only difference is in Class, you can create object over and over, where in structure, you have to create the second and third structure for 3 of them. Is that what you call the blueprint to create object?
If so, then I am starting to get it.
Thanks
In the Debug menu, there is Step Backward, or Alt [.
It's the same idea for a struct. The struct definition is the template for how a struct instance is laid out in memory.
That's the wrong way to think about things. Instead of thinking about the files where the functions are defined, the member functions of a struct are internal to the class. Whether the function definitions appear in the header file or in another .cpp file is really irrelevant.
The header file isn't the class blueprint -- the class definition, class InvItem, in this case -- is the blueprint, or template.
C++:
struct invItem
   double cost;
   int unit;
It's different because this struct doesn't have any member functions. It's also different in that the three data members are public.
In C++, the only difference between a struct and a class is that members of a struct are public, by default. That's the only difference. A struct can have member functions, just like a class.
Thanks for the reply.
I don't see Alt[ in debug menu. I see F11 step in, F10 step over and shift-F11 step out.
Yes, I think toward the last part, I realize the .h file is not the blue print, only the invItem is the Class, that is the blue print to create item1, item2 and item3.
I did not realize struct is a blueprint also. So the difference is struct are all PUBLIC . Class is more complicate with private and public. I have not learn struct can have member function yet.
In struct st, you access the member by st.cost, I have not seen in the invItem item1 that I can access item1.cost like in struct. Is this because double cost is PRIVATE. that if I declare double cost in PUBLIC, I can access from program using item1.cost = 6.95? If that is true, this clears up more question for me.
Thanks for explaining this.
No, it is a blueprint just like a class is. See page 592 of your book, where Gaddis introduces structures by defining a struct data type named PayRoll.
C++:
struct PayRoll
    int empNumber; // Employee number
    char name[SIZE]; // Employee's name
    double hours; // Hours worked
    double payRate; // Hourly pay rate
    double grossPay; // Gross pay
He then writes:
Gaddis said:
It’s important to note that the structure declaration in our example does not define a variable. It simply tells the compiler what a PayRoll structure is made of. In essence, it creates a new data type named PayRoll. You can define variables of this type with simple definition statements, just as you would with any other data type. For example, the following statement defines a variable named deptHead:
PayRoll deptHead;
After that that statement, there now exist "sub-variables" named deptHead.empNumber, deptHead.name, etc.
If you then have the following statement:
PayRoll teamLead;
you now also have "sub-variables" names teamLead.empNumber, teamLead.name, etc.
If PayRoll were a class instead of a struct, you could do the same two statements, and you would have the same "sub-variables". The only difference here is that you cannot access the "sub-variables" (member data) directly from your program. In a class object, only the member functions can access private member data directly.
The debugger has to be running for this option to appear.
Yes, if cost were listed among the public members of the class, you could access it directly from an object using the dot operator. This is not a good idea, as it defeats one of the major attributes of OO design, encapsulation -- a class should provide a set of accessors and mutators to limit access to the data members of a class.
Yes, I was running debug by hitting F5 first and stop at the break point before I check. This is the picture. I don't see it.
Thanks for clearing the private public variable up. I understand not to put that in public, just want to confirm I can do that if I put it in public and can use dot to access it.
Seems like after the first semester C++, things are getting much more complicate, it really takes time to really understand it. It's not like I can fly over the chapters.
Thanks for your time.
C++:
struct PayRoll
He then writes:After that that statement, there now exist "sub-variables" named deptHead.empNumber, deptHead.name, etc.
PayRoll teamLead;
Thank you for the explanation. I am getting this.
Thanks
Possibly Step Backward is no longer a feature in VS 2019. I'm running VS 2017, and it is there, but only if the debugger is running.
Here's what I see when the debugger is not running.
Here are the options when the debugger is running.
Thanks
Too bad, ha ha, maybe I should try to get the 2017! Believe me, I tried the alt-[ where it shows or not. It just gave me a "bing" sound.
I don't know how your 2017 is on this, my VS does not allow strcpy() and even strncpy(). I have to change the code in the book to strncpy_s() on all of them and I have look to get the length to put in the extra two parameters.
Thanks
I might have an English problem here. I read this CAREFULLY like 10 times, I cannot make heads and tails out of this. The question is written in the copy. I have no idea what the book refer all the 1st, 2nd, 3rd constructors etc. I copy the two pages in the book. They are continuous from one page to the next.
I labeled question (1) as 1st, 2nd and 3rd. I labeled questions(2) and (3) as 0, 1 and 2. Please help clarify (1) to (4) for me.
Thanks
For question (1), see Contents of InventoryItem.h (Version 3) on page 759. The "third constructor" is labeled "Constructor #3". It receives three arguments.
The statement that you asked about, is on page 761. It calls that constructor three times, once for each of the three elements of the array named inventory, supplying three arguments each time.
For questions (2) and (3):
The compiler chooses which constructor to use, by comparing the number and types of arguments that you give when calling the constructor, with the number and types of arguments in the constructors in the class definition. inventory[0] and inventory[2] are each constructed with one argument: a C-string. Therefore "Constructor #2" is used (because it receives one argument, a C-string). inventory[1] is constructed with three arguments: a C-string, a double and an int. Therefore "Constructor #3" is used.
For question (4), the "default constructor" is the one that has no arguments, in this case "Constructor #1".
Besides the different versions (2015, 2017, 2019, and earlier), there are different editions, such as Community Edition, Enterprise Edition, and one or two more that I don't remember. If you have the (free) Community Edition, maybe its features are limited. I have version 2017, but it's the Enterprise Edition.
Otherwise, I don't know why your version doesn't support Step Backward.
@jtbell explained this pretty well, but just in case, the constructors are numbered in the code you showed.
// Constructor #1
InventoryItem() - no parameters
// Constructor #2
InventoryItem(char *description) - a single C-string parameter
// Constructor #3
InventoryItem(char *description, double cost, int units) - three parameters
#2 and #3 use the parameter names that I suggested.
Thanks guys, I did NOT know it's referring back to the old stuffs. This is a new section Array of Objects, the book should say very specifically it refers back to P759.
Thanks jtbell, it really helps you have the book and gave me the page number. I have to go back and read over with the new understanding. I was pulling hair since last night on this. I was thinking my English cannot be that bad!
Hi Mark, my middle name is "CHEAP", I ain't paying no money for the version of VS that cost money! No walking back it is! 😊
Thanks both jtbell and Mark.
No, this isn't reasonable. The topics in this book and most other programming books build on each other, and aren't standalone. What you're asking for is like saying that every use of int should refer back to where this keyword was defined. Eventually the chapters would be mostly references back to previous material, with very few parts devoted to new topics.
I am running into problem with VS again. If you look at the invItem.h, if I use line11 to line27. It will FAIL and the error file is shown below. BUT if you block out line 11 to line27, the USE line 29 to line 44. It will work. Look at the two blocks of codes. THEY ARE EXACTLY THE SAME. I compare the two blocks a few times. They are exactly the same.
This is the invItem.h.
C++:
#ifndef invItem_H
#define invItem_H
#include <cstring>   // Needed for strlen and strcpy
#include <iostream>
class invItem
  private:
    char* description; const int L = 21;  double cost; int units;
  public:
//This part of the code will give error
    invItem item1()
    { char cA1[] = "Alan";
      description = new char[L];//0
      strncpy_s(description, L, cA1, L);
      cost = 0.0;   units = 0;}//2
   invItem item2(char *desc)//12
    { description = new char[strlen(desc)+1];//13
      strncpy_s(description, strlen(desc)+1, desc, strlen(desc)+1);//14
      cost = 0.0;   units = 0; }//15
    invItem item3(char* desc, double c, int u)//18
    { description = new char[strlen(desc) + 1];//19
      strncpy_s(description, strlen(desc)+1, desc, strlen(desc)+1);//20
      cost = c; units = u;}//21/*This is the exact code as above. If you use this part, it will work.
    invItem()   // Constructor #1
        cost = 0.0; units = 0;}// 2--Default values
    invItem(char* desc)   //12   Constructor#2
        cost = 0.0; units = 0; }//15---Default value
    invItem(char* desc, double c, int u)//18-Constructor#3,No default value
        strncpy_s(description, strlen(desc) + 1, desc, strlen(desc) + 1);
        cost = c; units = u;}//21 --From main()
This is the end of the working code*/
    ~invItem()  { delete [] description; }//42, 43, 44
//Mutator function only for Constructor#1
    void setDesc(char *d) {strncpy_s(description, L, d, L);};//5--d=cAr1
    void setCost(double c) { cost = c; }//7
    void setUnits(int u) { units = u; }//9
// Accessor functions
    const char *getDesc() const { return description; }    //25, 31, 37
    double getCost() const { return cost; }//27, 33, 39
    int getUnits() const { return units; }//29, 35, 41
#endif
This is the source.cpp
C++:
#include <iostream>
#include <iomanip>
#include <cstring>
#include "invItem.h"
using namespace std;
int main()
{//Create invItem object item1, to Constructor#1, set default values
   invItem item1;
   char cAr1[] = "Hammer";//3
   item1.setDesc(cAr1);//4--to mutator
   item1.setCost(6.95);//6--to mutator
   item1.setUnits(12);//8---to mutator
//Create invItem object item2 with one parameter
   char cAr2[] = "Pliers";//10--input parameter to item2
   invItem item2(cAr2);//11--cost and units by default
//Create invItem object item3 with 3 parameters
   char cAr3[] = "Wrench";//16
   invItem item3(cAr3, 8.75, 20);//17 parameters for item3
   count << "The following items are in inventory:\n";//22
   count << setw(20) << setprecision(2) << fixed << showpoint;//23
//Display item1 use item1. to access member functions
   count << "Description: " << item1.getDesc() << endl;//24
   count << "Cost: $" << item1.getCost() << endl;//26
   count << "Units on Hand: " << item1.getUnits() << "\n\n";//28
//Display item2
   count << "Description: " << item2.getDesc() << endl;//30
   count << "Cost: $" << item2.getCost() << endl;//32
   count << "Units on Hand: " << item2.getUnits() << "\n\n";//34
//Display item3
   count << "Description: " << item3.getDesc() << endl;//36
   count << "Cost: $" << item3.getCost() << endl;//38
   count << "Units on Hand: " << item3.getUnits() << "\n\n";//40
   return 0;
This is the error message for the block of line11 to line27.
Anyone can explain this?
No they are not.
Or he could look line by line.
"invItem item1()" is not the same as "invItem()"
And "invItem2(char *desc)" is not the same as "invItem(char *desc)"
And "invItem3(char* desc, double c, int u)" is not the same as "invItem(char* desc, double c, int u)"
@yungman, you have forgotten the most significant thing about overloaded functions.
Thanks guys, I found it. I deleted the program accidentally and I had to retype the program from my notes and somehow I typed invItem item1(), invItem item2() and invItem item3() in the .h file. When I check, I check the lines after this declaration line and totally missed it.
I was actually working on the next problem, but with this one opened, I accidentally went to the wrong window and deleted the codes and closed the program and lost everything. So I just typed the whole thing back from reading the notes I posed in post #91 really fast without thinking and wrote the declaration of the object item1,2 and 3 in it.
Thanks
  • Sad
Since this is no longer about strings, I'm going to close it. If you have a question about classes, please start a new thread.
  • Love
