Coriolis Force Direction with Rotating Ball and Velocities
The discussion focuses on determining the direction of the Coriolis force for a rotating ball with given angular velocity and two different velocity vectors. The Coriolis force is expressed as F = 2m(v x ω), where the vector product is essential for calculating the force direction. Participants note that while the vector product provides coordinates, it does not directly indicate the force's direction without further analysis. Calculations for the two velocities yield specific force components, indicating the need for clarity in understanding the Coriolis effect. Overall, the conversation emphasizes the importance of vector analysis in solving the problem.
buzzing
A rotating ball with rotational angular velocity ω= (0,0,ωz) . What is the direction of the coriolis force with the following velocities: Va = (Vx, Vy,0) ; Vb= (Vx, 0,Vz)
All i know about coriolis force is F= 2m(vχω). The question even doesn't say any angles. So i am not too sure if the question is right.
The Coriolis force is 2m times the vector product v x ω. Recall how to obtain the vector product using coordinates.
ehild
the vector product only gives a multipication of co ordinates but doesn't give the direction though.
The vector product gives the coordinates of the product vector. You can find from the components what angles the force vector enclose with the axes.
Show what you got for the Coriolis force in case of both velocities.
ehild
The two product for each velocity i got is (-WZVy,WzVx,0). and the next one is (0,WzVx,0).
Thanks for replies ehlid!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
