songoku
- 2,509
- 393
The diagram shows a circuit used for the investigation of photoelectric emission. The two electrodes E and F are made of different metals. The work function of electrode E is higher than that of electrode F.
Which of the following graphs show the variation the current (flows from E to F) versus voltage (of E with respect to F) when the two electrodes are illuminated with a uniform monochromatic light? Assume the magnitude of the saturation current for either electrodes is same during this experiment
Not sure
1. E has higher work function means that the electrons are harder to be released from E but I do not know how work functions affects the question
2. When current = 0, is the voltage = stopping potential?
3. My guess:
The graph starts from negative voltage, means that the voltage of E is lower than F. Photoelectrons will be attracted to F so the electrons will flow from F to E and current from E to F resulting in positive value of current. When the voltage changes (becomes more positive) the current will decrease until zero then flow in opposite direction resulting in negative value of current. The answer is C ?
Thanks
