IUPAC Names for Chlorinated Methylbenzenes: Analysis & Solutions
  • Thread starter Thread starter Krushnaraj Pandya
    Iupac
The discussion focuses on the acceptability of IUPAC names for chlorinated methylbenzenes, specifically evaluating four proposed names: 1-chloro-4-methylbenzene, 4-chlorotoluene, 4-methylchlorobenzene, and 1-methyl-4-chlorobenzene. The consensus is that the first name is correct, while the second is a common name rather than an IUPAC designation. The third name is deemed incorrect because chlorobenzene does not qualify as a pure hydrocarbon parent chain. The fourth name is also incorrect due to the priority of substituents being determined by alphabetical order, placing chlorine before methyl.
  • Understanding of IUPAC nomenclature rules
  • Familiarity with organic chemistry concepts, particularly regarding substituent priority
  • Knowledge of hydrocarbon structures and classifications
  • Ability to differentiate between common and systematic names in chemistry
  • Study IUPAC nomenclature rules for organic compounds
  • Learn about the priority of functional groups in chemical naming
  • Research the classification of hydrocarbons and their derivatives
  • Explore examples of common names versus IUPAC names in organic chemistry
Chemistry students, organic chemists, educators in chemical nomenclature, and anyone involved in the systematic naming of organic compounds.
Krushnaraj Pandya
among these, which are acceptable IUPAC names,
4-chlorotoluene
2. The attempt at a solution
1)First option seems correct but is chlorine a higher priority group than methyl?? or does chlorine get a lower number due to alphabetical order?
2)toluene is accepted by IUPAC so correct
3)I see no reason as to why this should be incorrect
4)if methyl has higher priority then correct, if there is no such priority and alphabetical arrangement is followed in this case then incorrect- besides doesn't the name chlorobenzene imply chlorine is at position 1?
I'd be very grateful for some insight
4-chlorotoluene
1st is absolutely correct
2nd one is correct and accepted by IUPAC but it is a common name and is not IUPAC nomenclature.
3rd is correct
4th is incorrect because alphabet is given priority.
3rd is correct
I thought so, but here's the twist. 3rd is incorrect, I can't figure out how
4th is incorrect.The alkyl group is given least priority.
you're right. 4th is incorrect and I understand that, but 3rd is incorrect too- why is that?
even though chlorobenzene is accepted by IUPAC
yes chlorobenzene is accepted but 1methyl 4 chloro benzene is not accepted
I got that. My problem is regarding 4-methyl chlorobenzene now
anyone?
3rd is incorrect because, by definition, the "parent chain" must be a pure hydrocarbon, and chlorobenzene isn't one.
any link for reference to this rule??
I can give you one, but these are the very basics. If the parent hydrocarbon would compose something other than only C & H, there would remain no basis for classification.
baldbrain said:
Tell me, what is the 'parent chain' or stem of the name 2-chloropropanol?
Just because it is propane doesn't make your earlier statement correct (perhaps it is, I don't know for sure).
If memory serves me well (won't be the first time it fails if I am wrong) IUPAC rules allow usage of non-systematic common names as long as the result is unambiguous. so chances are it all depends on how orthodox you want to be about naming.
baldbrain said:
This is absolutely correct. The '-oic acid' is a suffix (grammatically they would be 2 words, but relate it similar to -ol, -one, -amine etc. or any other suffix). The stem of this name is still toluene.
Edit: The stem of this name is still toluene.
The question asked by @sjb-2812 was about preferred IUPAC names.
And as far as the aptitude of the OP and, in general, homework assignments are concerned, only the 'preferred IUPAC name' is really of interest.
I gave them something easy to start with.
And as far as I know, it is correct. Look up any compound's 'preferred IUPAC name' on Wikipedia (I know it Wikipedia isn't fully reliable, nothing is, for that matter) and you'll find the 'parent chain' to be a pure hydrocarbon.
Do tell me if you find a compound that violates this rule.
If you're thinking biomacromolecules, I agree that their rigorous IUPAC names are unnecessary.
13K
