Homework Helper
Dearly Missed
- Messages
- 10,704
- Reaction score
- 1,723
Aleoa said:It's been a long time, I'm sorry.
Anyway, i calculated lim [itex](QR)^{n}[/itex], getting [itex] \begin{bmatrix}<br /> \frac{1}{5} &-\frac{4}{5} \\<br /> -\frac{1}{5}& \frac{4}{5}<br /> \end{bmatrix}[/itex].
In order to do so, i calculated [itex]QR[/itex], trasformed it in the form [itex]B\Lambda B^{-1}[/itex] and then i calculated [itex]lim (B\Lambda ^{n}B^{-1})[/itex]
If it's correct i continue with the exercise, calculating first of all lim [itex](RQ)^{n}[/itex]
Your calculations must be wrong: ##Q## and ##R## are stochastic matrices, so ##M = QR## is also a stochastic matrix; that is, its elements are ##\geq 0## and its columns sum to 1. Therefore, for any positive integer ##n## the matrix ##M^n## is also stochastic, as is ##\Pi = \lim_{n \to \infty} M^n##, provided that the limit exists (which it does in this case). Your limiting matrix should be of the form
$$\Pi = \pmatrix{\pi_1 & \pi_1 \\ \pi_2 &\pi_2}, $$
where ##\pi_1, \pi_2 > 0## and ##\pi_1 + \pi_2 = 1.##
You do not need to find eigenvalues or anything like that in order to find the limiting matrix ##\Pi##; just use the standard "equilibrium equations", to get a simple ##2
\times 2## system of linear equations whose solution gives you what you need. Of course, you could use eigenvalues, do diagonalization and all that in order to find the limit, but that is like using a sledgehammer to crack a peanut. Why do it the hard way, when the easy way is almost trivial?
