Correct way to write pi buckingham theorem
  • Thread starter foo9008
    Pi Theorem
13 replies · 3K views · last reply
foo9008
in this problem , the author make π1 = D(dp/ dx) / ρ( V^2) , and make π3 as μ/ ρVD , how if i want to make μ/ ρVD (reciprocal of reynold number ) as π1 and make D(dp/ dx) / ρ( V^2) as π3 ?
since we know that π1 is function of ( π2 , π3 )
is it necessary to change μ/ ρVD (reciprocal of reynold number ) to reynold number (ρVD / μ ) ?
which is correct ? Re = f ( D(dp/ dx) / ρ( V^2) , Ks/ D ) or μ/ ρVD = f ( D(dp/ dx) / ρ( V^2) , Ks/ D ) ? which is correct ?
  • Worked example from a fluid mechanics text applying dimensional analysis to pressure gradient in a pipe, listing variables, dimensions, and the Pi group derivation with exponent matching.
  • Worked dimensional analysis from a fluid mechanics text: exponent equations for pi3 = mu/(rho V D), then the non-dimensional relationship and rearrangement into the Darcy-Weisbach form h_f = lambda (L/D)(V^2/2g).
wow , thi is considered as advanced physics question ?
I don't see any difference between taking the reciprocal of Reynold's number and taking actually Reynold's number as ##\pi_1##.
Why?
If you take ##\pi_1 =f (\pi_2 , \pi_3)## for some function ##f## of ##\pi_2 , \pi_3## in which case you can find a function ##g## such that ##\pi_1^{-1} = g(\pi_2 , \pi_3)##; so it doesn't matter which one you choose your ##\pi_1## to be, your function will of course be different for different cases, but you don't seem to know what is your function ##f##, right?
You didn't state what is your precise problem here?
It's pi Buckingham theorem, can I still do so?
Re = f ( D(dp/ dx) / ρ( V^2) , Ks/ D ) or μ/ ρVD which is 1 / Re = f ( D(dp/ dx) / ρ( V^2) , Ks/ D ) ? which is correct ?
Do you know what is f here?
Ff means function, where pi1 is the function of pi2 and pi3...
I mean is f given explicitly?
? What do you mean?
I mean do you know how is f given? I mean do you know what is f(\pi_2, \pi_3) what is this function of \pi_2 and \pi_3?
Dun know
As it mentioned in one of the pics you rearrange only for convenience, i.e. it doesn't matter if you take Reynold's number or the reciprocal of Reynold's number as a function of the other dimensionless variables since you can always take the reciprocal of the function if you have ##Re = f(\pi_2 , \pi_3)## then you can take ##1/Re = 1/f = g(\pi_2,\pi_3)##.
If on the other hand ##f## were given then you'd know how to rearrange the equation.
