Richard Ayers
- Messages
- 2
- Reaction score
- 0
Hi, I have seed of a project forming but need some help with some physics in it :
What I'm trying to do :
I need to weigh a sample using a load cell, so far so good, but the load cell is on a moving platform, a ship.
I think I know that if the object being weighed and the load cell were moving at the same speed then the data from the load cell would be accurate, I think the analogy is 'a box on a load cell all being lifted by a crane', once the acceleration has stopped and the vertical movement is steady the load cell data will be correct but when lifting starts or stops things like momentum and acceleration come into play.
In the crane scenario you could just wait for the steady movement phase and collect your data then, but on a ship in any sort of wave movement there is no steady phase, you're either going up or down (and sometimes corkscrewing horribly and worrying about the security of your breakfast).
The current thinking is to have 2 load cells, 1 with a known weight as some sort of reference and another with the sample on. I can also insert an accelerometer into the kit and get vertical (or XYZ) acceleration in m/s or G.
I was planning to continuously sample the load cell and accelerometer data, correct the 2 mass values using the accelerometer data, calculate some kind of rolling average over a number of readings looking for a value that has an error within some set bounds and then supply this as the mass of the sample.
Other information - Samples may weigh from 1g up to 45Kg, I'm assuming that momentum is going to cause larger issues at the 45Kg end of the spectrum. Precision wise I need to be at the 0.1g level at the lower end and can live with 5g at the top end, the precision of the data-stream is mostly controlled by the analog to digital convertor that turns the load cell data into machine readable data, perhaps I should use the term accuracy for my 0.1g and 5g limits rather than precision ?
I know from experiments that the movement of the ship does cause variations in the load cell data, and that variation pushes the accuracy of the data outside acceptable limits.
So I guess the actual questions are :
1. Have I missed something obvious...
2. Given a m/s or G value how do I correct a mass
Many thanks for reading...
R
R
