Correlation Dimension, what does it mean?
The correlation dimension is a measure of how a set of points occupies space, often related to fractal dimensions. A correlation dimension of 1.5 in a two-dimensional space indicates a complex structure that fills the space more than a one-dimensional line but less than a full two-dimensional area. Conversely, a correlation dimension of 0.5 suggests a more sparse distribution. The correlation dimension cannot exceed the dimensionality of the space being analyzed, whether finite or infinite. Understanding this concept is crucial for accurately interpreting results in computational physics and chaos theory.
NeoDevin
I wasn't sure where precisely to put this, hopefully it gets an answer here.
In my computational physics class we just learned about the correlation dimension. I know how to compute it, but don't quite know what it means.
I learned roughly that the correlation dimension of something is a measure of how well it covers the space, but I'm not too clear on the details.
For example, if I have a two dimensional space, and a plot with a correlation dimension of say 1.5, what does that mean? How about if it were 0.5? Does the meaning change if you are considering an infinite space, or a finite one? You can't have a correlation dimension higher than the dimension of the space you are in, right?
I need to learn this because our next assignment is all about correlation dimension, and I'd like to know what it is I'm computing, rather than just putting numbers in a formula (or writing a program to put numbers in a formula).
Thank you guys in advance for your help.
Mathematics news on Phys.org
The correlation dimension (denoted by ν) is a measure of the dimensionality of the space occupied by a set of random points, often referred to as a type of fractal dimension.
There are a few concepts to model what is dimension in geometry for the application in chaos theory.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 45 ·
  • · Replies 19 ·
