Could mirrors on the Moon illuminate Earth during night?
  • Context: High School
  • Thread starter Thread starter Saleh0003
    Earth Mirrors Moon
36 replies · 5K views
Saleh0003
if we fix huge amount of mirrors on surfface of moon...can we obtain light on Earth during night ?
Most of the light would not be reflected toward the Earth.
Yes.
But we already obtain light on Earth at night from the moon, without mirrors, so I'm wondering why you think that we might want more light at night.
A better idea would be to simply paint the Moon white. As is, it's charcoal grey, although it doesn't look like it in the night sky.
Is the question to do with installing solar reflectors on the Moon so that these could provide an additional energy source for Earth?
If so then yes it's possible from an engineering point of view, but pointless because very little of the light already reaching the Earth from the Sun is utilized directly as an energy source.
OmCheeto said:
Yes.
coz...surface of moon is rough so it is not reflecting properly sunlight but with mirrors, we can obtain it at night which may plays an important role in food chain
The position of the moon with respect to the Earth is not fixed. At some times during the month, the moon is actually located on the opposite side of the Earth from the night side. What will you do with your mirrors then?
you are right but this is just supposition that if it happens can we obtain same light of sun as we obtain during day?
I suppose it would work, theoretically.
We discussed telescopes on the Moon, which is basically your idea on a smaller scale.
The biggest "selfie" mirror ever?
We discussed telescopes on the Moon, which is basically your idea on a smaller scale.The biggest "selfie" mirror ever?
yeah! As people have much craze of selfies these days ...so it will work in better way :)
Goodness! Why would you want to abolish nighttime? That would screw things up beyond all recognition...
lot of sins take place at night...Probably we achieve peace on Earth :)
Or as Black Sabbath put it: The moon is just the sun at night
Yes, many nocturnal animals might go extinct.
That would be a shame.
Sin is a 24 hour a day business. I think that having no day/night would make things worse, not better. :oops:
I agree with you, day and night is a natural phenomena, if we broken up this, Life on Earth is to be broken,that will be horrible.
If we could significantly increase the amount of energy we receive from the sun, wouldn't that increase "global warming"?
It wouldn't increase the greenhouse gas effect as such, but still the extra heat would accumulate, so that would add extra heat on top of existing global warming.
It would not only affect long term climate trends but would completely change local weather patterns, I would expect this resulting in the complete loss of polar ice in a short timescale.
Sins? Like watching adult TV? Or even turning on the electric lights according to some religious varieties.
Lots of problems ran through my mind. This was one of them.
This "mirrors on the moon" is similar to someone's "energy beam from space" idea.
I believe it was @nsaspook that posted something about the current power level of moonlight being 400,000 times less than from the sun. (Very interesting experiment!) Increasing the albedo alone, by painting the moon white, would yield light that is about 40,000 times less than from the sun. Has anyone successfully grown tomatoes in the shade?
So using mirrors would be the only logical solution.
But they would have to continuously adjustable, as the sun-moon-earth angle would have the reflected sunlight just beaming back out into space most of the time.
But as I mentioned in the "energy beam from space" idea thread, if anything goes wrong, and the beam should somehow become too focused, we end up with disaster.
The engineering solution to lighting the nightside of the Earth is not mirrors on the Moon but mirrors in orbit. There is quite a bit of literature about it.
It's much more feasible:
- much closer
- don't need to climb into and out of a moon's gravity well to visit/service
- in micro-g so structure can be gossamer-light
- reflection can subtend an arbitrarily large angle of the sky
- can be moved around as needed
- etc.
The question is: would we want to, and should we?
At a fundamental level, the energy from the sun is useful because it is low in entropy, it only comes from one direction at a time. If we had sunlight from a variety of directions then the entropy of that energy would be higher and it would be less useful for doing work.
A heat engine will only operate if you have a heat sink. If you have heat all around the heat engine it cannot operate, even though it has more energy available, the energy cannot be converted into work. Same idea with the sun. Everything on Earth is essentially a heat engine of one sort or another with the direction of the sun being the heat source and every other direction as the heat sink. If we mirrored the moon we would get more heat, but less useful energy then we have now.
I don't think this is true. It isn't simply a matter of the Earth being 'surrounded' by a heat source. It's much more complicated than that.
I'm running some baseline tests (at nanowatt resolution) this week with the new gear on the Raspberry PI with about 240 Watts of panels as the moon gets closer to full every night and using the Portland moon charts to give me the percentage of full and distance. I hope to post some charts on the moon power thread if the weather holds. The forecast so far looks good for this time of year if we don't get junk that night.
http://archive.kgw.com/weather/images/core/7day.jpeg
The brightest white paints are based on Titanium compounds. so that project of painting the Moon white would need to begin with Titanium mining and processing.
- much closer
- etc.
Saleh0003, the OP, mentioned in post #6 that he wanted it for food production.
Interesting idea. And we already have data on the effects of extended sunlight hours on crops
How Midnight Sun Affects The Environment
Parts of Alaska such as the Tanana Valley between Fairbanks and Delta and the Matanuska Valley near Anchorage are famous for their production of gigantic vegetables. Among the largest vegetables have been a 138 pound cabbage from Wasilla, and 18.9-pound carrot from Palmer, and a 1,287 pound pumpkin from Nikiski on the Kenai Peninsula.
I think it would take me a week to eat a 20 lb carrot!
Should we do it? IMHO, no. At least, not yet.
And since it's purpose is food production, I think we can rule out painting the moon.
Mirrors will not work always as moon's position with respect to the Earth is not fixed
So what are you going to do with those mirrors then; p
Same thing we do with mirror arrays now. Make em tiltable.Anyway, it's still a far better option to put em in Earth orbit. Their location above the night side as well as their orientation to the Sun is built right in.
Yes this option may work better than putting mirrors on moon from engineering point of view
