Could wind turbines be used as wind breaks in open farm land
Wind turbines are not effective as windbreaks in agricultural settings due to their height and design, which can increase wind speeds at ground level rather than reduce them. The discussion highlights that traditional windbreaks, such as hedges or low shrubs, are more effective in minimizing surface wind velocities and preventing soil erosion. Historical practices, such as planting Cypress seedlings for windbreaks, demonstrate the importance of maintaining appropriate vegetation height and density. Overall, trees and shrubs are more cost-effective and practical solutions for wind management on farms compared to wind turbines.
  • Understanding of wind dynamics and airflow patterns
  • Knowledge of agricultural practices related to soil erosion and wind management
  • Familiarity with wind turbine mechanics and operational limitations
  • Awareness of effective plant species for windbreaks, such as caraganas and Cypress
  • Research the impact of windbreaks on soil erosion and crop yield
  • Learn about effective species selection for agricultural windbreaks
  • Investigate the mechanics of wind turbines and their effects on local wind patterns
  • Explore historical agricultural practices for maintaining windbreaks
Agricultural engineers, farmers, environmental scientists, and landscape architects interested in optimizing wind management and soil conservation strategies in farming practices.
firefox5926
my question is would a line of wind turbines have a comparable effect to a wind break in reducing wind velocity
Maybe, but it would be more expensive and a great deal more unsightly to construct a bunch of wind turbines in place of planting a row of trees.
I see a problem with this idea, in order for the blades to act as wind breaks the blade tips would have to travel very close to the ground, at that level the airflow would be turbulent setting up potentially dangerous vibrations in the blades.
Lines of trees that have bare trunks with a high canopy of foliage actually increase the wind speed close to the ground. It requires an understory of low shrubs to reduce surface wind velocities.
By obstructing higher airflow, a line of wind generators will actually increase the local wind speed below the blades.
I agree with Jobrag and Baluncore. I'm a bit confused by the terminology in the initial posts. Where I live (at least when I was on farms back in the 50's and early 60's) we used hedges such as caraganas for windbreaks. Sometimes there were a few trees on either side of them, but that was decorative.
That aside, I agree that wind turbines wouldn't work for what I think of as a "windbreak". They will of course reduce and/or redirect airflow, but not at ground level and not to a huge degree.
theOrange said:
If it is possible to use wind turbines to reduce the power of a hurricane
If that's to what the OP was referring, it's a whole different scale than what came to my mind. I was thinking of the kind we had to cut down on soil erosion in dry times on the farm or minimize snow drifting in winter due to surface winds. Hurricane taming wouldn't work on the same principle (I don't think) because of the sheer vertical area they cover and hurricanes are more susceptible to interference a higher altitudes where the "rim" speed is lower.
You may be right, either way trees are probably more cost effective.
Way back in the 1920s, Cypress seedlings were handed out for free by the Department of Agriculture so farmers could plant wind breaks. These formed good wind break hedges that only required to be trimmed once each year. Unfortunately, farmers are busy and kept putting off the inconvenient job of trimming the top of 12 foot high hedges, so the hedges became lines of trees, now between 4 and 8 foot diameter at the base, 100 foot high, dropping big old branches on buildings and equipment. The area under the trees is now bare of other vegetation and clear of low branches, which makes an efficient wind tunnel for wind obstructed by the middle part of the tree.
That outcome is quite the opposite to what was originally intended, wind speeds below the trees increased.
Where trees are used as wind breaks, the species selected should remain low, such as a shrub, or have foliage that fills the area between the trees as close to the ground as possible.
Yes - one can use tall trees, but at some distance from buildings and equipment. One would need lower shrubs, but also rows of trees.
I've noticed that some windbreaks are not well maintained, and I've seen dead trees that ostensibly will fall if the wind is too high.
Wind turbines extract a portion of the wind, and most have the blades well above the ground, which is where one wants the wind break. In addition, wind turbines have a cutoff speed at which prevents them from turning too fast.
  • · Replies 22 ·
  • · Replies 48 ·
  • · Replies 72 ·
11K
43K
  • · Replies 24 ·
