Could you make a fluorescent lamp with krypton?
  • Thread starter Thread starter 00152
    Lamp
Creating a fluorescent lamp with krypton instead of neon or mercury is not feasible due to the fundamental differences in how these gases operate. Mercury vapor is preferred for its ability to produce significant UV light, which excites phosphors to emit visible light. Neon and krypton are classified as discharge lamps rather than fluorescent lamps, and while krypton discharge lamps are available commercially, they are costly. The discussion highlights that the properties and requirements for a krypton lamp would differ significantly from those of neon or mercury lamps. Overall, while krypton can be used in discharge lamps, it does not function effectively as a fluorescent lamp.
00152
Could you make a fluorescent lamp with krypton instead of neon or mercury? The wavelength doesn't really matter its just if its actually possible and if it is what pressures and voltages should be used.
Wavelength absolutely matters. Mercury vapor is used because it produces a lot of UV light when excited by a current. The UV excites the powdered phosphors that coat the inside of the tube, which then glow with a spectrum that appears white to the eye. I don't think neon and krypton lamps do the same.
i meant it doesn't really matter to me, but think neon and mercury lights work on the same principal you just add differend additives to shift the wavelenghts. But my question was: if you can make a neon lamp /which you can/ how differend would be the properties and requirements of krypton lamp
Neon and mercury are not fluorescent lamps. They are discharge lamps. You can buy a krypton discharge lamp commercially. They are extremely expensive - as is krypton.
Hey, money is no object when you are trying to kill superman. ;)
thanks...any other use for krypton?
Aside from the difference between fluorescence and ionization (arc lamps ionize the atoms)-
http://amglo.com/krypton_arc_laser.html
