I Coulomb gauge implies instantaneous radial electric field?
  • Thread starter Thread starter Bob44
    Electromagetism
In the discussion on Coulomb gauge and instantaneous radial electric fields, it is established that the scalar potential is governed by Poisson's equation, leading to instantaneous solutions. The vector potential is decomposed into transverse and longitudinal components, with the transverse component obeying a wave equation that incorporates retarded solutions. The radial electric field derived from these potentials includes both instantaneous and retarded terms, but the instantaneous contributions from the longitudinal field are canceled by the transverse field, preserving causality in observable electric fields. The conversation highlights that while mathematical equations can suggest instantaneous effects, physical observables do not violate causality when considering the full context of Maxwell's equations and charge conservation. Overall, the discussion emphasizes the importance of recognizing the distinction between potentials and fields in the context of causality.
Bob44
Scalar and vector potentials in Coulomb gauge
Assume Coulomb gauge so that
$$\nabla \cdot \mathbf{A}=0.\tag{1}$$
The scalar potential ##\phi## is described by Poisson's equation
$$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$
which has the instantaneous general solution given by
$$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$
In Coulomb gauge the vector potential ##\mathbf{A}## is given by
$$\nabla^2\mathbf{A}-\frac{1}{c^2}\frac{\partial^2\mathbf{A}}{\partial t^2}=-\mu_0\mathbf{J}+\frac{1}{c^2}\nabla\frac{\partial\phi}{\partial t}.\tag{4}$$
We decompose the vector potential ##\mathbf{A}## into its transverse and longitudinal components
$$\mathbf{A}=\mathbf{A}_\perp+\mathbf{A}_\parallel.\tag{5}$$
We define the transverse current density ##\mathbf{J}_\perp## by subtracting off the longitudinal component ##\nabla \partial \phi/\partial t## from the total current density ##\mathbf{J}## to obtain
$$\mathbf{J}_\perp=\mathbf{J}-\varepsilon_0 \nabla \frac{\partial \phi}{\partial t}.\tag{6}$$
Therefore the transverse component of the vector potential ##\mathbf{A}_\perp## obeys the wave equation
$$\nabla^2\mathbf{A}_\perp-\frac{1}{c^2}\frac{\partial^2\mathbf{A}_\perp}{\partial t^2}=-\mu_0\mathbf{J}_\perp\tag{7}$$
which has the retarded general solution
$$\mathbf{A}_\perp=\frac{\mu_0}{4\pi}\int \frac{\mathbf{J}_\perp(\mathbf{r}',t_r)}{|\mathbf{r}-\mathbf{r}'|}d^3r'\tag{8}$$
where
$$t_r=t-\frac{\mathbf{r}-\mathbf{r}'}{c}.\tag{9}$$
The longitudinal component of the vector potential ##\mathbf{A}_\parallel## obeys the Poisson equation
$$\nabla^2 \mathbf{A}_\parallel=-\frac{1}{c^2} \nabla \frac{\partial \phi}{\partial t}\tag{10}$$
$$\mathbf{A}_\parallel=\frac{1}{4\pi c^2}\int \frac{\nabla'(\partial\phi/\partial t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{11}$$
Point charge at the origin connected to a wire
Let us consider a time-dependent point charge ##q(t)## located at the origin, which is connected to a wire that carries current to or from the charge.
At any point from the origin the radial electric field ##\mathbf{E}_\parallel## is given by
$$\mathbf{E}_\parallel=-\nabla \phi - \frac{\partial \mathbf{A}_\parallel}{\partial t}\tag{12}.$$
We have
\begin{eqnarray}
\phi(\mathbf{r},t)&=&\frac{1}{4\pi\varepsilon_0}\frac{q(t)}{r},\tag{13}\\
-\nabla \phi&=&\frac{1}{4\pi\varepsilon_0}\frac{q(t)}{r^2}\hat{\mathbf{r}},\tag{14}\\
\frac{\partial\phi}{\partial t}(\mathbf{r}',t)&=&\frac{1}{4\pi\varepsilon_0}\frac{\dot{q}(t)}{r'},\tag{15}\\
\nabla'\frac{\partial \phi}{\partial t}(\mathbf{r}',t)&=&-\frac{1}{4\pi\varepsilon_0}\frac{\dot{q}(t)}{r'^2}\hat{\mathbf{r}}'.\tag{16}
\end{eqnarray}
Substituting eqn.##(16)## into eqn.##(11)## and using the standard Poisson integral of a radial gradient we obtain
\begin{eqnarray}
\mathbf{A}_\parallel(\mathbf{r},t)&=&\frac{1}{4\pi\varepsilon_0}\frac{\dot{q}(t)}{c^2 r}\hat{\mathbf{r}},\tag{17}\\
-\frac{\partial \mathbf{A}_\parallel}{\partial t}&=&-\frac{1}{4\pi\varepsilon_0}\frac{\ddot{q}(t)}{c^2 r}\hat{\mathbf{r}}.\tag{18}
\end{eqnarray}
Therefore by substituting eqn.##(14)## and eqn.##(18)## into eqn.##(12)## we find that the radial electric field ##\mathbf{E}_\parallel## is given by
$$\mathbf{E}_\parallel=\frac{1}{4\pi\varepsilon_0}\left(\frac{q(t)}{r^2}-\frac{\ddot{q}(t)}{c^2r}\right)\hat{\mathbf{r}}.\tag{19}$$
Does eqn.##(19)## violate causality since it is an instantaneous expression?
Longitudinal electric field isn't an observable, E is. (Save some electrostatic near field stuff when E is approx ##E_{\parallel}## and complete far field where E is approx ##E_{\perp}##). The question seems a bit ill framed in it's foundations, can a math equation violate causality? Sure. Can physics? No, not when you account for Maxwell + charge conservation + retarded boundary conditions.
Here, when you look at the total field $$E = E_{\perp} + E_{\parallel}$$ any instantaneous bit from the longitudinal electric field is cancelled exactly by the transverse field, so there is nothing causality violating in the observable E.
Likes Dale and TSny
Bob44 said:
Does eqn.(19) violate causality since it is an instantaneous expression?
As was pointed out by @QuarkyMeson, no, because it is only part of the field.
However, Maxwell’s equations admit causality-reversed solutions. So you can get non-physical solutions. These can be found using advanced potentials.
However, these solutions have a light-speed delay, just to the past instead of the future. So if you find an “instantaneous” transfer of information in the field then you made a mistake.
Likes QuarkyMeson and TSny
But how could the retarded transverse field cancel the instantaneous longitudinal field as it takes a finite time for the transverse field to get to the observation point whereas the longitudinal field is there already?
This is shown in Jackson's 2002 paper "From Lorenz to Coulomb and other explicit gauge transformations" (Am J Phys, 35:832-837). Basically, he shows that in the Coulomb gauge $$-\frac{\partial \mathbf A_C}{\partial t} = \frac{1}{4\pi\epsilon_0}\int d^3 x' \left( \frac{[\rho]}{R^2}\mathbf{\hat R} + \frac{[\partial \rho/\partial t']}{Rc}\mathbf{\hat R} - \frac{[\partial \mathbf J/\partial t']}{Rc^2} - \frac{\rho}{R^2} \mathbf{\hat R}\right)$$where the square brackets indicate retarded quantities. The final term is a non-retarded quantity that exactly cancels out the non-retarded quantity from ##-\nabla \Phi_c## leaving only retarded quantities in the total E field.
Of course, as I mentioned before, for every causal retarded solution there is a non-causal advanced solution. But either way there are no instantaneous terms in the fields, just in the potentials.
Likes QuarkyMeson, Bob44, Ibix and 2 others
Thanks for the reference!
https://arxiv.org/abs/physics/0204034
Thread 'The rocket equation, one more time'
I already posted a similar thread a while ago, but this time I want to focus exclusively on one single point that is still not clear to me. I just came across this problem again in Modern Classical Mechanics by Helliwell and Sahakian. Their setup is exactly identical to the one that Taylor uses in Classical Mechanics: a rocket has mass m and velocity v at time t. At time ##t+\Delta t## it has (according to the textbooks) velocity ##v + \Delta v## and mass ##m+\Delta m##. Why not ##m -...
  • · Replies 21 ·
