Coulomb's Law and spheres Problem
4 replies · 3K views · last reply
frankfjf
Of the charge Q initially on a tiny sphere, a portion q is to be transferred to a second, nearby sphere. Both spheres can be treated as particles. For what value of q/Q will the electrostatic force between the two spheres be maximized?
(k)(q1q2)/r^2
I posted a similar problem concerning an electric field some time ago, and am attempting to use the same solution, that is, taking the derivative of the equation I end up with, but the derivative ends up being zero for me. I end up with:
k(Q-q)q / r^2
And then after factoring out k/r^2, I'm left with just (Q-q)q. I tried doing a derivation using the product rule, but I just end up with zero. When I try to derive this, I get:
1 * (1-1) + (Q-q) which just leaves me with Q - q, which is not the answer. What am I doing wrong?
You differentiated the equation with respect to...?
Ah nevermind, upon multiplying the q back into the (Q-q) and then deriving, I get the correct answer. However, can it be said as a rule of thumb that you should factor AFTER taking the derivative, or are there situations where you should factor beforehand?
Basically I used df/dq.
There's no difference between: [tex]\frac{d}{dq}\left(q(Q-q)\right)[/tex] and [tex]\frac{d}{dq}\left(qQ-q^2\right)[/tex], and this holds true no matter what kind of functions are in the product. (They should be continuous of course.)
