- 22,832
- 14,880
... a rank 2 antisymmetric tensor field to be precise.jbriggs444 said:The electromagnetic field is a [pair of] field(s) in this sense.
That seems just semantics. But ok, the perturbation in the field between creation and annihilation is say 100 ns long and, from a distance, I have 100 feet in space where the electric field is non zero, while it is zero before and after. In the middle I only have the static electric field of the (pair of) charge(s) pointing where the source was r/c seconds before.jbriggs444 said:A "field" in the sense that we use the term is a function defined over a space.
Similar to the way that it makes sense to speak of the speed of surface waves on a lake without needing to talk about the speed of the lake. The water is already there. Its surface has a height everywhere, even before we throw a rock in.
Sorry, but that’s just nonsense. The field is always there whether nonzero or not. Zero is a perfectly valid field value.SredniVashtar said:The argument of the field being 'already everywhere' should not apply here because the charges responsible for it were not always there.
I am seeing this from the point of view of classical ED. Fields are an expression of the presence of a charge.Orodruin said:Sorry, but that’s just nonsense. The field is always there whether nonzero or not. Zero is a perfectly valid field value.
Charges are not responsible for the existence of the field itself, they are the cause of divergences in the field, as described by Maxwell’s equations.
That is a common misconception due to Maxwell’s equations being linear. It is however not really accurate, in classical electromagnetism, the field is always present. It may be zero, but it is present.SredniVashtar said:I am seeing this from the point of view of classical ED. Fields are an expression of the presence of a charge.
Yes.SredniVashtar said:Is that a wave?
Right. You created a dipole, allowed it to exist for a short duration and then extinguished it. From a classical viewpoint, the result is a wave. A wave that persists after the dipole is gone.SredniVashtar said:I am seeing this from the point of view of classical ED. Fields are an expression of the presence of a charge.
Are we still talking of classical electrodynamics? Because, to my knowledge, charges are the sources of the electric field, and currents are the sources of the magnetic field. They still are the sources (in the sense of the reason for the field presence - or if you prefer it "the nonzero value of the ever-present field") even when the field lines curl around each other. The 'curling' is the result of the relativistic transformation of the electric field of charges in a moving frame reference and of the finite speed of propagation of light.Orodruin said:That is a common misconception due to Maxwell’s equations being linear. It is however not really accurate, in classical electromagnetism, the field is always present. It may be zero, but it is present.
Divergences in the field are the expressions of the presence of charges.
Ok, let's change the timescale: instead of 20 ns, let's make it 4 billion years. We sit in the middle of this event. Would you call that perturbation that has been static for 2 billion years minus the few microseconds or milliseconds during the initial transient a "wave"? I wouldn't . I call that a static field. If I create a dipole in the lab, by bringing two spheres with opposite charge close to each other in the arc of say ten seconds, in the time I turn around to the instrument to measure the field, there is an electrostatic field, not a wave. We should rewrite ALL books of physics if that were not the case.jbriggs444 said:Yes.
This is nonsense. In an otherwise empty universe that initially contains an electron and positron at rest, they will attract and annihilate, thereby emitting electromagnetic radiation. Afterwards that universe is charge-free, but the outward-propagating radiation persists for all time, as it must since energy is conserved.SredniVashtar said:Because after the first million years, I am pretty sure we can consider the transient that changed the value of the electric field from zero to a nonzero value spent and no longer relevant to all practical purposes.
2 billion light years from the position of the temporary dipole there will be a wave, yes. What is your point?SredniVashtar said:Ok, let's change the timescale: instead of 20 ns, let's make it 4 billion years. We sit in the middle of this event. Would you call that perturbation that has been static for 2 billion years minus the few microseconds or milliseconds during the initial transient a "wave"?
Who ever said they are in an empty universe and they are free to recombine?renormalize said:This is nonsense. In an otherwise empty universe that initially contains an electron and positron at rest, they will attract and annihilate, thereby emitting electromagnetic radiation. Afterwards that universe is charge-free, but the outward-propagating radiation persists for all time, as it must since energy is conserved.
My point is that the wave is the transient, and the static field we perceive after the transient has died out is... a static field. Not a wave.jbriggs444 said:2 billion light years from the position of the temporary dipole there will be a wave, yes. What is your point?
If the universe is non-empty then an argument that the local region has a static field becomes invalid. If they are not free to recombine then how do we explain the hypothetical situation in which they did recombine.SredniVashtar said:Who ever said they are in an empty universe and they are free to recombine?
I did. It's a simplified model that is both consistent with physics and represents a counterexample that clearly invalidates your reasoning and assertions.SredniVashtar said:Who ever said they are in an empty universe and they are free to recombine?
