Can the summation formula be proven by counting a set in two ways?
  • Thread starter Thread starter Robb
    Counting Set
The discussion revolves around proving the summation formula $$\sum_{k=0}^n k\left( \binom{n}{k} \right) = n * 2^{n-1}$$ by counting a set in two different ways. Participants clarify that binomial coefficients should replace fractions in the original equation. A hint is provided to consider the expression $(1+1)^{n-1}$ and calculate it using both direct evaluation and the binomial formula. The goal is to show that both methods yield the same result, demonstrating the equivalence of the two approaches. The conversation emphasizes the importance of correctly formatting LaTeX for clarity in mathematical expressions.
Robb
Mod note: Fixed numerous problems with LaTeX
Also, the fractions shown throughout should instead be binomial coefficients
1. Homework Statement
prove the summation formula by counting a set in two ways
$$\sum_{k=0}^n k\left( \frac n k \right) = n *2^{n-1}$$
LHS = ##k \left(\frac n k \right) = k \left (\frac n 0 \right) + k \left( \frac n 1 \right) + k \left( \frac n 2 \right) + ...+ k \left(\frac n n \right) = k * 2^{n}##
RHS = ##n \left (\frac n k \right) * 2^{-1}##
Part two is just some analysis on my part. I'm not sure how to choose a set to count. A hint from the back of the book says to split the RHS into subsets corresponding to the term on the left. First attempt at latex so hope its not too confusing.
Please make sure your LaTeX is correct by using the preview button.
Is there a way to see how the actual equations will show once posted? The preview just shows the LateX string.
I've fixed it, but there were many errors.
This means that your LaTeX is not well-formed. If it's not right, keep revising it until it shows up as you intend in the Preview.
Here are some of the things that were wrong:
LaTeX expressions need to start and end with either ## pairs (inline LaTeX) or $$ pairs (standalone)
frac needs to be preceded by \, as in \frac. Most or all of yours were missing the slash.
The left and right commands can't have spaces between \ and left or right, and there can't be a space between left or right and the enclosing symbol. IOW, do this \left(, not this: \ left (.
There's a link to our tutorial at the lower left corner of the input pane.
Much obliged!
Also, the equation you're working with is wrong, I believe, and you mistakenly have fractions throughout your work.
In the summation, you should have binomial coefficients, not fractions.
##\binom n k##, not ##\frac n k##
The command I used is \binom
OK. That was my intent (obviously). Is there a way to preview so that I can see what the output would look like once it posts? Then I will know I messed up before I send it to the whole world.
Yes, use the PREVIEW button.
It only shows me the LateX not how it would appear once posted.
Scroll up or down (I don't remember which) to see how it actually renders.
Instead of "\binom" you can also get ##{n \choose m}## by typing {n \choose m}.
Likes Robb
If you do it correctly it shows up. If it does not there are errors in parsing your equations.
Likes Robb
Did you make any progress on this? As a hint, I'd suggest considering ##(1+1)^{n-1}##.
I guess I'm not sure what this does for me.
ok, I'll nudge you a bit more:
consider ##(1+1)^{n-1}## and calculate it two different ways... one, directly ##=(2)^{n-1}##, which seems a lot like your right hand side. Apply the binomial formula for the other way of calculating... what does that look like?
Ok, I think I get it. When they ask to count two different ways, I assume I am suppose to count one way on side and another way on the other and if I get the same result then they are equivalent?
Basically -- it kind of depends on how you think about it. In this case I think it's a little stronger:
You know that ##(1+1)^{n-1} = (1+1)^{n-1}##
and you compute / expand / show it 2 different legal ways (for this problem: one is by making use of parenthesis and addition, the other is the binomial formula) but you know those two different forms are equivalent precisely because ##(1+1)^{n-1} = (1+1)^{n-1}##
Awesome! Thanks so much!
  • · Replies 22 ·
  • · Replies 18 ·
