Coupled oscillator mass on spring question?
The discussion revolves around a physics homework problem involving two coupled oscillators with masses m and M = 2m connected by springs. The main tasks include writing the equations of motion, defining normal modes, finding their frequencies, and describing the motion of the masses. The equations of motion are derived, but there is uncertainty regarding how to calculate the normal mode frequencies and express the time-dependence of the oscillations. Participants suggest reviewing textbooks for clarity, emphasizing the straightforward nature of the problem for those familiar with the concepts. Understanding normal modes is crucial, as they represent oscillations where all components vibrate at the same frequency.
coffeem
An object of mass m and another of mass M = 2m are connected to 3 springs of spring constant horixontally. The displacement of the two masses are defined as x and y. When x = y = 0, the springs are unextended.
a) Write down the two coupled equations of motion.
b) Define the term normal mode.
c) Find the frequencies of the normal modes.
d) Write down the time-dependence of x and y for the case of normal modes of motion and for the case of general motion.
e) Using appropriate sketched, describe the motion of the two masses for each normal mode.
mx1(dot dot) = -kx1 - k(x1-x2)
2mx2(dot dot) = -kx2 - k(x2-x1)
Mode at which all of the components in a couples system oscillate with the same frequency.
I don't know how to do this but believe it involves finding a determinent.
Again I do not know how to do this.
mode.
? Not sure.
Any help given would be appretiated.
You said that the normal modes are motions where all parts vibrate with the same frequency. Can you write an general expression that represents a solution of this form?
No. Sorry I don't know how to do this can you explain this to me? thanks
This is a very straight-forward question, and you either know how to do it or you don't. If you've never seen a question like this before, just read a textbook.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
