Crash of two cars: What was the speed of car 1 at imact?
  • Context: Graduate
  • Thread starter Thread starter crash37
    Car Cars Crash Speed
The discussion revolves around estimating the speed of car 1 at the moment of impact with car 2, considering the dynamics of the collision, including the rotational motion of car 2 and the conservation of momentum. The scope includes theoretical considerations of momentum and energy transfer during a car crash.
  • One participant describes the scenario where car 1 impacts car 2, causing a 180-degree rotation of car 2, and questions how to apply conservation of linear momentum and energy principles in this context.
  • Another participant assumes that car 1 hit car 2 at a 30-degree angle from the horizontal, introducing a geometric consideration into the analysis.
  • A different participant highlights the importance of accounting for energy lost due to friction and deformation during the collision, suggesting that the final state of the cars complicates the analysis of energy transfer.
  • Another participant challenges the assumption that all energy remains within the two-car system, indicating that external factors may influence the outcome.
  • A participant shares a personal account of the collision, noting the lack of skid marks and the severity of injuries sustained, which raises questions about the energy absorbed during the crash and the potential for crash data to provide insights.
Participants express differing views on how to approach the problem, with some emphasizing the need to consider external factors and energy loss, while others focus on the theoretical application of momentum and energy conservation. No consensus is reached on the best method to estimate the speed of car 1.
Limitations include the lack of concrete data on traction, energy loss, and the specifics of the collision dynamics, as well as the absence of skid marks and detailed crash data.
crash37
Car 1 hits car 2 and sets car 2 into 180 degree rotation. Both cars are of similar dimensions and about the same weight. What was the speed of car 1 at impact?
Assume that car 2 had a speed of 20 mph (29.3 ft/sec) in the opposite direction at impact.
I am stuck in using the conservation of linear momentum because the rotation of car number 2 involves a rotation of 180 degrees.
The kinetic energy of car 1 is converted into the rotational energy of car 2.
Pi rad = 180 degrees. How do I substitute this into omega squared of 1/2 I omega squared?
I assume that car 1 hit car 2 at an angle of 30 degrees from the horizontal.
You'd have to know the amount of traction there was, then estimate how much energy was lost due to friction and deformation of the car bodies. At the end of the collision the car is no longer rotating, so you don't know how much energy was involved, or the rate of rotation of the car during the time it was rotating.
Conservation of momentum would need to include the change in momentum of the Earth (also a tiny bit to the air), otherwise, if the Earth is ignored, then momentum of the 2 cars is not preserved, since I assume they both end up stopped.
you're assuming that all energy stays in the 2-car system, which is false.
Instead of trying to look for formulas to plug and chug, try thinking about it first.
Curl,
I agree with you. I don't have any skid marks - car 1 hit me so fast that he was not able to react. I don't know how much energy was absorbed by the deformation of cars 1and 2.
I was hit when I was decelerating in car 2. The end of my fibula where it connects to my ankle bone was shattered. The doc said that this was caused by the impact. Perhaps crash data can answer my question.
I appreciate your comment.
