Create a recursive function in prolog
The discussion revolves around creating a recursive function in Prolog that sums two lists element-wise and counts repeated elements between two lists. Participants explore various approaches to defining and implementing these functions, focusing on the syntax and logic required for recursion in Prolog.
  • One participant requests help in creating a recursive function to sum two lists element-wise, defining the expected output format.
  • Another participant suggests that summing a single list is a basic task and provides an example of summing a list to demonstrate the concept.
  • A participant clarifies that they have already completed the single list sum and seeks assistance specifically for summing two lists and counting repeated elements.
  • One participant advises on reformulating the problem in logical terms to facilitate a recursive definition, emphasizing the importance of addressing the heads and tails of the lists.
  • Another participant introduces the use of the list syntax [H|T] and provides examples of how to implement a sum function that returns both the sum and intermediate steps.
  • A suggestion is made to utilize the debugger in SWI Prolog for tracing execution, indicating a potential tool for understanding the recursive process.
  • A participant presents a proposed implementation of the sum function, using pattern matching and recursion to achieve the desired outcome.
Participants express differing levels of familiarity with Prolog syntax and recursion, leading to various interpretations of how to implement the requested functions. There is no consensus on a single solution, and multiple approaches are discussed.
Some participants mention the importance of understanding list syntax and recursion in Prolog, while others highlight the need for clarity in defining the problem logically. There are unresolved aspects regarding the implementation details and specific requirements for the functions.
Wez
can anyone help me out with this please
i want to create a recursive function in prolog to do the following thing
sum lists(X; Y;Z) holds for lists X = [x1; : : : xn], Y = [y1; : : : yn] and
Z of numbers if and only if Z = [z1; : : : zn] and zi = xi+yi (1  i  n).
Technology news on Phys.org
This is 'Hello World' level for lists in Prolog.
For starters create a 'function' that sums a list.
sum([1,2,3],X).
X = 6.
You should get the idea.
Do you self study Prolog?
yeah i do...i have that one done...but i wanted for two list
e.g [1,2,3,4] and [1,2,3,4] would output [2,4,6,8]
and for the second would be how many elements are repeated
e.g [1,2,3,4] and [1,6,7,4] would output 2
thanks
First, state it in a logical manner. For instance,
Z is the sum of lists X and Y iff Z_i = X_i + Y_i. This is good, but this is not a recursive enough definition to be implemented directly in prolog. Perhaps a better way of saying the same thing would involve mentioning the first elements of the lists X, Y, and Z, and then what has to be true of the lists' tails...
So you would write:
listSum(X, Y, Z) :- < something about the lists' heads > , <something about the lists' tails>.
Are you familiar with the syntax of the lists? namely [H|T]? Notice that you can use [H|T] for your 'return' variable not just for 'incoming' variable this is what I mean:
e.g.
Code:
sum([1,2,3,4,5],Sum,ReverseSteps).
Sum = 15
ReverseSteps = [15, 14, 12, 9, 5]]
you are familiar with this
Code:
sum([],0).
sum([H|T],Sum):-
    sum(T,Sum1),
    Sum is Sum1 + H.
the only thing I can think you are not familiar is to pass something back in the list like this
Code:
sum1([],0,[]).
sum1([H|T],Sum,[Sum|ReturnList]):-
    sum1(T,Sum1,ReturnList),
    Sum is Sum1 + H.
the solution to your original problem is similar in concept to this - how to use the return of predicate in the list. In the example it made sense to jump into recursion in first step, it is not so in your problem.
HTH.
Aside. If you are using SWI Prolog, I recommend to use the debugger for tracing the execution - it is not great but it helps.
Code:
sum(X,Y,Z) :- X == [], write(over).
sum(X,Y,Z) :- [Tmp1 | X_new] = X, [Tmp2 | Y_new] = Y, Tmp is Tmp1 + Tmp2, [ Tmp | Z ]=Z1 , sum(X_new, Y_new, Z1) .
  • · Replies 17 ·
