radaballer
- 86
- 0
Is it possible to create a ball with a positive magnetic core and a negative exterior? And vice versa?
Alexandre said:First of all, you're using the wrong terminology. Magnets don't have negative or positive charges, they have north and south poles, that's very different from electric charges. You can have a positively or negatively charged particle but you can't have a north pole without having the south pole on the same object, in other words you can't have a magnetic monopole, if you break up a bar magnet into peaces every single one of them will have north and south poles. Field lines of magnetic field should be closed curves because otherwise it would violate Gauss's law for magnetism (which states that divergence of magnetic vector field is zero).
I think it's impossible to create a perfectly shaped sphere with magnetic field lines uniformly pointing outwards everywhere on its surface.
berkeman said:Those balls have north and south poles.
radaballer said:How would all of the balls stick together? Wouldn't they repel?
radaballer said:Is it possible to create a ball with a positive magnetic core and a negative exterior? And vice versa?
