Creating a Variable Bend in a Function with Preserved Properties
  • Graduate
  • Thread starter Thread starter Ad VanderVen
    Bend Variable
7 replies · 2K views
Ad VanderVen
TL;DR
With a given function how to make a variable bend.
I have the following function: $$y = s-1 + exp (-ln (-1 / (s-1)) x)$$ with 0 < s < 1. For ##x = 0## you have ##y = s## and for ##x = 1## you have ##y = 0##. The function has a fixed bend, but now I want to make the bend variable, while the two properties, that for ##x = 0## you have ##y = s## and for ##x = 1##, ##y = 0##, should remain unchanged. How do I do that?
Where did you get that equation from? Do you realize it can be simplified to ## y = (1-s)^x + s - 1 ##? What is 'bend'? If you mean you want a similar function with an increased radius of curvature, try ## y = (1-s)^{x^2} + s - 1 ##, although that has a very different behaviour for ## x < 0 ##. How do you think you could modify this to get a curve that is similar for any value of ## x ##?
I want a similar function with the same restrictions as described above with a parameter, say ##b##, representing the curvature.
Have you looked at the function I suggested? How do you think you could incorporate the parameter ## b ## into it?
Yes, I looked at the function you suggested and the function $$s-1+(1-s)^{x^b}$$ with ## 0<b<1 ## would do perfectly. I cannot say how grateful I am..
What could you call such a function? Is it a special case of some well-known function?
I'm not a big fan of naming things: some people (and some educational cultures) get over-obsessed with naming and categorization.
I suppose you could call it a sub-exponential function (and for b = 0.5 a half-exponential function) but I have only seen this term used for increasing functions (i.e. ## s < -1 ##) so I think using that term in this context would not be helpful.
