Critical point of a piecewise function
8 replies · 3K views · last reply
mohammed El-Kady
TL;DR
critical point to piece wise function
If the function is not differentiable at point. Can we consider this point is critical point to the function?
f(x) = (x-3)^2 when x>0
= (x+3)^2 when x<0
he asked for critical points in the closed interval -2, 2
Math_QED said:
Please define critical point.
you don't know it?
" When dealing with functions of a real variable, a critical point is a point in the domain of the function where the function is either not differentiable or the derivative is equal to zero." definition from Wikipedia Looks like the answer is yes. (derivative discontinuous)
mohammed El-Kady said:
you don't know it?
Different people use different definitions... The answer to your question depends on the definition you are using.
thank you
I don't know which definition the problem ask for. I know the definition of the derivative, but someone solved it with the differentiability , so i need to be sure from it.
critical point vis-a-vis finding minima/maxima? Yes, you have to evaluate those points. Think of a "V" shaped function. How else would you find the minimum.
I don't think you meant to do this, but you have not defined the function at x=0, so it is not a critical point of the function.
