MHB Are Critical Points and Roots Interchangeable in Math?
Critical points and roots are not interchangeable terms in mathematics. A critical point refers to values of x where a function's first derivative is zero or undefined, while roots are the values of x that make the function equal to zero. In solving rational inequalities, critical values indicate boundaries for the solution set, distinguishing between where the function is defined and where it equals zero. For example, in the inequality provided, critical values partition the x-values into regions that determine the solution set. Thus, critical roots are numerical values, while critical points represent coordinates in a Cartesian plane.
gevni
Might be I am asking a silly question but really want to clarify that would critical points and roots are same terms use interchangeably? I mean we can use critical point as value of x and root also as value of x then what is the difference between?
Mathematics news on Phys.org
It has been my experience that a critical value is an input to a function such that the function's first derivative is either zero or undefined. A function's root(s) is/are the input(s) which cause the function to return zero, also known as the zeroes of a function.
In solving rational inequalities, critical values are where the expression under scrutiny equals zero or is undefined. Those values mark the boundaries for the solution set.
for example ...
$\dfrac{x^2-1}{x+2} \ge 0$
critical values are $x \in \{-2,-1,1\}$
the three critical values partition the set of x-values into four regions ...
$-\infty < x < -2$,
$-2 < x < -1$,
$-1 < x < 1$,
and $x > 1$
The "equals to" part of the original inequality occurs at $x = \pm 1$
The "greater than" occurs over the intervals $-2 < x < -1$ and $x > 1$
So, the solution set is all $x$ such that $-2 < x \le -1$ or $x \ge 1$
One additional point- critical roots are numbers while critical points are, of course, points. If I were asked to find the critical root of $y= x^2- 6x+ 10= (x- 3)^2+ 1$, I would answer x= 3. If I were asked for the critical point, I would answer (3, 1).
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
  • · Replies 27 ·
