Cross-linking Polyvinyl Alcohol
  • Thread starter Thread starter SkepticJ
    Alcohol
9 replies · 14K views
SkepticJ
Some friends and I are working on a movie, and we need a very stringy clear slime; like is produced with polyvinyl alcohol cross-linked with disodium tetraborate. Only we need it to be food-safe, so we can't simply use that. Is there another way to cross-link PVA into a stringy slime using edible chemicals?
Chemistry news on Phys.org
A few days ago I watched the movie Charlie and the Chocolate Factory, and therein was a slime that had pretty much the mechanical properties I'm looking for, and was edible. It wasn't transparent, but milky translucent. And green -- but that's just food coloring. What could it have been made of?
Is cross-linking polyvinyl alcohol using an edible compound just not possible, at least yet?
OP ,
I happen know that PVA with suitable macromers in water formulation would have the properties that you've mentioned ; also you can experiment with saturating water with the PVA and perhaps PVAc in water .
Thanks, guys. :smile:
Re: Methylcellulose
I got some of it weeks ago, and tried it out. It's not the right texture. It's not stringy at all, but more like a yogurt.
The other stuff mentioned looks like it will work.
Are you referring to Carboxymethyl cellulose ? From what I remember this is not exactly clear in water except at lower concentrations . It can get viscous as it is used as a lubricant .
I see that galactose dialdehyde can be used as http://www.sciencedirect.com/science?_ob=ArticleURL&_udi=B6TFF-43HJRBJ-2&_user=10&_rdoc=1&_fmt=&_orig=search&_sort=d&view=c&_version=1&_urlVersion=0&_userid=10&md5=bb39c841992b0482f858b0de5a3ea6bd"
Finding a food grade aldehyde that I would trust will be a problem though.
chemisttree said:
Use the methocel to provide the base viscosity and blend with an extract of boiled okra for the stringiness.
Ah, mucilage - brilliant idea, there. :smile:
I don't think so, but I wouldn't rule out that being what it is. The container just says methylcellulose -- bought it from a special FX supply company.
It looks quite clear in water to me; though if I mix up a really thick batch (a ball of it will hold its shape against gravity, mostly), it's translucent.
